MS20 VCF/VCA
Page 1 of 1 [9 Posts]
vladosh
PostPosted: Tue Sep 27, 2011 1:47 pm    Post subject: MS20 VCF/VCA Reply with quote  Mark this post and the followings unread
 Filesize:  301.48 KB
 Viewed:  313 Time(s)
citric acid
PostPosted: Sat Oct 15, 2011 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
hi vlad,
you are the god of stripboards ...
thanks i will try this...
http://soundcloud.com/citric-acid-303
vladosh
PostPosted: Sun Oct 16, 2011 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hehe Smile thanks Citric .. i still haven't finished this one .. i think i will move to pcb's ,just finished the steiner filter on a pcb and it's so easier than stripboard
Greetings
citric acid
PostPosted: Sun Oct 16, 2011 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Greetings
steiner filter wow... do you share this too.... sorry for my questions im so bad , everry time asking and giwing nothing back ...shame Embarassed Rolling Eyes
vladosh
PostPosted: Sun Oct 16, 2011 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
i made a pcb for the steiner filter from the yusynth page http://yusynth.net/Modular/index_en.html .. actually got made for me for cheap i'd say (around 4 euro ) ,since i have no material for making my own pcb's .. however it's way easier than making stuff on stripboard ,very clean work all one need to take care of is to make the wiring neat
ericcoleridge
PostPosted: Mon Oct 31, 2011 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
just wondering if you'd made progress on this one? I'm mainly looking for a layout of the VCA. I'll probably give your stripboard layout a go if not. I've got several Rene Schmidt late MS20 clones that I'd like to start building modules for, and I'd like to include the VCA as well.
Greetings
ericcoleridge
PostPosted: Mon Oct 31, 2011 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Greetings
vladosh
PostPosted: Mon Oct 31, 2011 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi ,I'm wiring the module just now and i'll prolly try it out tomorrow but mine is not a great build just so you know ,i'll see how it goes and i'll write back the results i use the scheme from this post http://www.electro-music.com/forum/topic-46571.html&postorder=asc which is actually the same from Marjan's page just missing one trim pot .
vladosh
PostPosted: Tue Nov 01, 2011 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
The VCA works but not a good one ,maybe it's my build .. it can be used for percusive things i suppose ,it's kind of missing the fine range and it's better to have attenuator on it i think since other levels on my synth are i guess different ..
