4046 Pitch Tracker - Turn clicks into lasers
Page 3 of 3 [58 Posts]
Goto page: Previous 1, 2, 3
Draal
PostPosted: Tue Apr 02, 2013 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dogenigt wrote:
I am integrating the 4046 module into a larger lunetta synth - so only square waves will come in, do you think the 4049/4069 will add something to the sound even though the signal is squared in the first place anyways?
of course I could just test this out myself, I might anyhow but I don't see how you could "square up" a signal which is already squared... Very Happy
I've built my first tracker just like it is in the Nic Collins book; with the 4049 as preamp. Realistically, it's not essential in our lunetta since most of the stuff we will push through the 4046 will already be square/square-ish. My more recent tracker builds don't use the 4049 and work just as well as my first one.
That said, I have heard slight variation in sound when I sweep the 4049 gain pot. Adds a bit of hair to the sound but not a must build Wink .
With the 4049 and say a 1/4 jack wired to accept input from a guitar, mic, etc., the addition of non square signals can be accomplished. (I need to diagram that sentence).
Zontar Prevails!
Dogenigt
PostPosted: Tue Apr 02, 2013 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
[quote="Draal"]
Yeah, I've got my own copy of Handmade Electronic Music Wink
It's a brilliant idea though and included in my future build no doubt!
www.dogenigt.com
Everything should be made as simple as possible, but no simpler. - Albert Einstein
Dogenigt
PostPosted: Tue May 21, 2013 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I am having a little headache about something here.
I want to have diodes on my 40106 pulse outputs for mixing but when I connect this output through the diode to the input of the 4046 it doesn't work. It's like there's no input.
I could mix with resistors but then the voltage drops from my reference HIGH doesn't it? (9V in my case)
www.dogenigt.com
-minus-
PostPosted: Tue May 21, 2013 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Try a 100K resistor to GROUND after the diode. See if that works.
Draal
PostPosted: Wed May 22, 2013 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I have mixed signals with a resistor ladder or r/2r and ran them through the pitch tracker without issues (all I care is that I get something at a reasonable volume level ultimately) Smile .
I don't think I've used diodes to mix my signals into the tracker in the past so I'm also curious about this. I did have a 3 input Nand array made of diodes and a transistor. I plugged in 3 oscillators and ran the output of the diode Nand "module" into the pitch tracker and got output. Just another idea to try Smile . Of course, I expect a simpler solution from one of the luantics here Wink .
I got the idea from http://www.play-hookey.com/digital_electronics/dtl_gates.html when I was short of CMOS NAND chips.
This schematic specifically:
Maybe worth a try. Helps prevent a bit of bleed-through.
 Filesize:  9.49 KB
 Viewed:  4674 Time(s)
Zontar Prevails!
Dogenigt
PostPosted: Wed May 22, 2013 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys! I solved this buy running the "dioded" signal through a schmitt trigger (40106) Smile
www.dogenigt.com
izash
PostPosted: Fri Aug 12, 2016 5:19 am    Post subject: CD4046 Reply with quote  Mark this post and the followings unread
Output 1 sounds amazing. Output 2 sounds great too but seems to respond to the negative edge of the pulse. great delay effect!
Here I am 4 years later. Thank you guys for some amazing ideas.
synthesist wrote:
hey
did anyone try to listen to the output of pin1 and pin2 on the cd4046?
Cause I made some similar circuits like the pitchtracker and if you are lucky you get to here this weird bitcrushing-like sound on these outputs.
Draal
PostPosted: Mon Sep 05, 2016 3:42 pm    Post subject: Re: CD4046 Reply with quote  Mark this post and the followings unread
synthesist wrote:
hey
thumright Still one of my favorite chips to work with. Now, back to my crypt...
Zontar Prevails!
