Joined: Dec 02, 2010 Posts: 106 Location: Victoria BC
Posted: Mon Apr 16, 2012 7:58 pm Post subject:
Paul,
Does it make life easier to mount the board parallel to the panel like that rather than use some kind of L-bracket? What kind of hardware do you use to do it? Those stand-offs look like rawl-plugs!
As for the beautifully printed panel design, I won't even ask. There's obviously some kind of witchcraft or voodoo involved.
Joined: Mar 07, 2007 Posts: 4579 Location: London, UK
Audio files: 172
Posted: Tue Apr 17, 2012 5:36 am Post subject:
Richard,
I've tried all sorts of mounts on my builds. I've tried L-brackets both screwed on, collared around a pot and soldered. I've tried pot-mounted, and parallel mounted. This is the second parallel mounted board mount I've done, and it just seemed easier to mount given how much stuff was on the panel. Those are just wood dowels I used for the spacers this time (didn't have any nylon of that quantity), I stiffened the ends of the dowels with cyanoacrylate before drilling them so they'd not split so bad.
The panel graphics are photographic inkjet paper, which was sealed with polyurethane and adhered to the drilled steel panel. There is a tendency for these to peel their edges over time if you're not careful. I'm getting better with that though. I always print a mockup and use that for the panel drilling, then do the photographic quality one later. Usually a couple spray coats of polyurethane to get a nice shine, matt finish actually works better than glossy.
For a board the size of the SN-Voice I think the mount was appropriate. Also the board is surrounded by connectors. Hard to mount perpendicular unless you built a plate to mount it onto. _________________ Garret: It's so retro.
Parker: Like, old and outdated. Home,My Studio,and another view
While not a finished module yet, I had to post an initial video of the circuit.
It's my first Arduino project and is a CV Quantizer
Get this Mosc, it worked first try done on perfboard AND it was translated from a Japanese blog! http://gtbts.tumblr.com/post/7353518380/section2-quantizer
I am also just about finished with the ENS-76 VCO option 3, but i'm working with Bernie to figure out why the envelope isn't working. Has anyone built the option 3 before? _________________ http://www.youtube.com/user/borisandfef
Very cool. It's a must have module on a voltage controlled modular. The fact that it worked when first turned on is a quantum mechanical effect, best ignored in normal existence. If it happens again, then you are in another universe than I. _________________ --Howard
beautiful cabinet loydb have enjoyed very much watching the progress on this. keep up the good work. _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any
Audio files: 172
Posted: Sat Apr 21, 2012 4:55 pm Post subject:
Rebuilt my Frac case today. It turned out to be a major undertaking. Basically all it was originally was two pieces of plywood holding the racks together. I added a top and bottom, swapped the racks around and installed a multiple in the edge of one, repopulated the modules into it with the aid of a thread tap tool (some of those holes were shot), recabled everything, balancing the power supplies (I hope) and then put a piece of plexiglas on the back to keep the dust out.
Pretty top, black trim, racks are almost unbent.
Filesize:
1.74 MB
Viewed:
348 Time(s)
Repopulated frac racks. Much more structurally sound.
Filesize:
1.91 MB
Viewed:
388 Time(s)
Plexiglas to keep the dust out. I'll cover the power supplies eventually.
Filesize:
2.37 MB
Viewed:
361 Time(s)
I feel a little shy posting in this thread after seeing so many beautiful, professional-looking panels and stuff. Perhaps I'm out of place here because my builds are less polished, and are standalone sound boxes instead of racks and panels and modules. I dunno, they have a certain style that is me, I guess...
Audio files: 54
Posted: Sun Apr 22, 2012 10:29 am Post subject:
RingMad wrote:
I feel a little shy posting in this thread after seeing so many beautiful, professional-looking panels and stuff. Perhaps I'm out of place here because my builds are less polished, and are standalone sound boxes ...
Looks fine to me. I have lots of standalone boxes that look just about like that. Build up a big supply of them, then you can hook up just the ones you need at any one time.
Posted: Mon Apr 23, 2012 5:45 am Post subject:
Building Tools...
I'm just getting started, so I'm building tools before I do more "actual" building...This one is Ian Fritz's transistor matching circuits, combined with a big honking switch ... using a pair of 9V batteries to make the box simple.
Filesize:
112.21 KB
Viewed:
194 Time(s)
Filesize:
131.44 KB
Viewed:
205 Time(s)
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Mon Apr 23, 2012 7:14 am Post subject:
Re: Building Tools...
elmegil wrote:
This one is Ian Fritz's transistor matching circuits...
Gotta build me one of those! Printed out the symple schematics but haven't put it together yet. _________________ Looking for a certain ratio since 1978
Thanks to those who liked my boxes. I don't have any new ones coming soon, so I will try to make some progress on my Lunetta CMOS suitcase-synth thing. Unless I get distracted by someone's cool circuit, like I was for the last 3 boxes!
Modded fairly heavily... added a manual reset switch and a clock LED, changed a cap in the rate circuit so I could go slower, used a different counter...added a pin header output in addition to the 1/4" jack. Using a +/- 15V supply and a different zener (didn't have any 9.1's handy).
On the breadboard it adjusted perfectly, but soldered up on protoboard for some reason I can't get the second op amp position to null all the way to zero. With one amp it went to 4.8mV and swapping them it went to 2.2mV. But both of them nulled to zero in the first position.
Learned a lot about case drilling/mounting pin headers doing this. I need to get a bunch more 1/4" #4 bolts
Filesize:
123.76 KB
Viewed:
200 Time(s)
Filesize:
73.92 KB
Viewed:
223 Time(s)
Filesize:
66.86 KB
Viewed:
198 Time(s)
Filesize:
67.44 KB
Viewed:
188 Time(s)
Joined: Oct 21, 2006 Posts: 292 Location: Orlando, FL (US)
Posted: Sat Apr 28, 2012 9:55 am Post subject:
I've actually had a productive couple of months, so far -
- Made Panels for my SN Voice and Super Controller and fixed the numerous problems they had.
- 2 TH VCA- 1's and 2 Yusynth VCA's
- 2 4 input mixers
- MFOS Wave Freaker
- x0xbox!! I've wanted one of these forever. Can't wait to start the modding.
- 4046 VCO
MFOS Wave Freaker
Filesize:
2.83 MB
Viewed:
204 Time(s)
SN Super Controller is finally fully working and has a panel
Filesize:
1.35 MB
Viewed:
195 Time(s)
SNVoice Finally works right and has a panel.
Filesize:
1.27 MB
Viewed:
197 Time(s)
Dual 4 input mixer (based on the Yusynth schematic)
Filesize:
1.8 MB
Viewed:
196 Time(s)
2 TH VCA-1's and 2 Yusynth VCA's
Filesize:
3.52 MB
Viewed:
198 Time(s)
_________________ When they plug me in the lights go down in Hong Kong.
Audio files: 172
Posted: Sat Apr 28, 2012 11:27 am Post subject:
crashlander42 - Nice panels! I was wondering how to fit the SN-stuff into smaller formats. Nicely done. Great graphics too.
and ringmad - those boxes look great. You shouldn't be shy! _________________ Garret: It's so retro.
Do you have a link to the Quantizer infor? It looks like it has a lot channels?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
