2012 Build Pictures
Page 2 of 16 [384 Posts]
Goto page: Previous 1, 2, 3, 4, ..., 14, 15, 16 Next
Audio files: 550
PostPosted: Mon Feb 06, 2012 4:05 pm    Post subject: Dronoscope
Subject description: Elektor Oscillographics + TV
I just finished the Dronoscope (well 99%, I need to replace one switch for aesthetic reasons)
It started out when I found the Elektor Oscillographics circuit (posted here)
I have a couple of small TV's which I was planning to use as visualizers
(maybe even make a synth module out of one) and this seemed like a nice
circuit for it.
I first started working on the elektor circuit itself, and made some small
modifications to make it more usefull for drones. By itself it produces nice
visuals and a droney sound but the fun starts of course when you
modulate it. So I started making some LFO's then some VCO's to change
the sounds some more, a filter seemed usefull and after a couple of
months I made so much extra stuff that I would need a really big case to
fit it all in. That's when I saw the beautiful boxes build by Captain Biscuits
and this made me decide to cut the whole project into smaller parts.
I had a really nice case i found at thrift shop and the TV just fitted in so
I worked with that. It was quite a challenge to get everything in and
especially how to mount the TV tube.
but Im VERY happy with the result. Laughing
The TV is still in working condition and it can also take external deflection
signals. The amp of the TV can be used for other signals and it's
attached to an internal speaker. I also amplified the TV audio to 10Vpp so
it can be used as white noise if you don't connect anything to the antenna
input. And there is a comparator circuit in there aswell to convert the
noise (or another signal) to a square/pulsewave.
Here's a demo video (I'll probably make it longer later).
TV tube mounted, now the rest, hmm,..
 Filesize:  695.99 KB
 Viewed:  254 Time(s)
The wiring process.
 Filesize:  612.4 KB
 Viewed:  226 Time(s)
The finished Dronoscope.
 Filesize:  564.78 KB
 Viewed:  249 Time(s)
a relaxing game of PONG after all the work to show the TV is still fully functional.
 Filesize:  521.66 KB
 Viewed:  230 Time(s)
PostPosted: Mon Feb 06, 2012 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
umschmitt - That synth sounds awesome. I thought the DS7 clone was a drum module, but yours sounds like an awesome little bass synth too. Does it do both? could it be cv controlled as a bass synth?
Phobos - absolutely amazing job! That is so cool and looks very professional. And the pong is a nice touch too Very Happy
JacobWatters.com
umschmitt
PostPosted: Tue Feb 07, 2012 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks ! That was the idea : make it a dirty and usable little synth. Yes, it still does the «vintage» drum module sounds, now amidst many other things… (some of them not fully explored yet !) Voltage control for the pitch is a classic mod here (I have hard times setting the MCV24 for a decent tracking range, though) ; I also added another CV input for VCF or VCA modulation.
I do agree. I love those spirals !
::U::N::S::C::H::N::E::L::L::
PostPosted: Tue Feb 07, 2012 4:22 am    Post subject: Re: Dronoscope
I just finished the Dronoscope...
this is ridiculous awesome!
too much coffee
fonitronik at
Audio files: 340
PostPosted: Tue Feb 07, 2012 4:38 pm    Post subject: Re: Dronoscope
too much coffee
Absolutely wholeheartedly agreee! Mr. Green
Muied Lumens Base Star
Audio files: 550
PostPosted: Wed Feb 08, 2012 4:16 am    Post subject: Dronoscope demo videos Reply with quote  Mark this post and the followings unread
Thanks guys Razz
2 more videos:
the first one demonstrates some of the Dronoscope functions.
the second one has some nice spiral action.
Cool
tjookum
Audio files: 26
PostPosted: Wed Feb 08, 2012 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
amazing work phobos, what a machine!
Hunter S. Thompson
movies
noise
dougseidel
PostPosted: Wed Feb 08, 2012 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
That is totally the coolest thing ever! Very beautiful.
http://dougseidel/tumblr.com
jordroid
PostPosted: Wed Feb 08, 2012 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! I love that dronoscope, super cool.
Here is a project i built after pouring through all the great info that Jurgen Haible has left us. I wanted to do a sort of tribute project incorporating some of his ideas, and came up with a tabletop filter unit.
It has a pair of low pass filters that can be used separately, in series, or in parallel, inspired by the descriptions of Jurgen's JH-5 synth.
Each filter gets its own LFO, with three modes of LFO modulation (LFO A to VCF A, LFO B to VCF B - LFO A to both VCFs - LFO A plus LFO B to both VCFs) The summed control voltage to VCF B can be either inverted or not, for low pass panning. LFO A uses the trick from the SOST flanger, with a three position switch for triangle, slewed square or sample and hold.
There is an NE570 compressor and JFET distortion per side, using dual pots and sharing a knob.
There is one NE570 enveloper follower normalled to input A, with attenuverters to send the envelope to filter A and B.
 Filesize:  103.62 KB
 Viewed:  250 Time(s)
 Filesize:  92.95 KB
 Viewed:  217 Time(s)
Audio files: 140
PostPosted: Wed Feb 08, 2012 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Much better use for that box than storing cigars. Looks and sounds great. Smile
umschmitt
PostPosted: Thu Feb 09, 2012 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Storing cigars ? I guess it's about my tour de force, then (or am I wrong ?). Thanks a lot ! But it's a small thing compared to the masterpieces presented on this topic (including Jingle Joe's post nuke farm punk design). I definitely need to post more examples of what this box offers soundwise. The percussive sounds - with triggering signal modulating VCO or VCF - are quite cool. And output fed back in the filter, mmmm…
(one can notice here that I'm rather satisfied)
Audio files: 140
PostPosted: Thu Feb 09, 2012 12:40 pm    Post subject: Re: Dronoscope
Outstanding, Phobos. wow!
Audio files: 140
PostPosted: Thu Feb 09, 2012 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice box! Let's hear some music...
wmonk
PostPosted: Sun Feb 12, 2012 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
First module of 2012 for me. The ChaQuO by Ian Fritz. Finally got a front panel for this one!
I love this module!
Woody
20120212-chaquo.mp3
Very simple patch with the ChaQuO to try out the quadrature sine oscillator and the chaos.
 Filename:  20120212-chaquo.mp3
 Filesize:  5.11 MB
 Downloaded:  502 Time(s)
Weblog!
magman
PostPosted: Sun Feb 12, 2012 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've actually had a very productive year getting some modules finished and working, but I've been very lax in posting them on here.
Time to fix this, so here goes with the first module I finished this year, an Oakley Ring Modulator.
This is an early board I won in a raffle at the Synth-DIY UK meeting a couple of years ago. It appears to be a FRAC style layout for the pots (less than the MOTM standard), so I had to use smaller knobs than usual for this module.
I've actually had this built for quite a while, I just never got round to testing it.
That's one down, now for the next 60 odd.
Magman
Completed Oakley Ring Modulator.
 Filesize:  3.1 MB
 Viewed:  229 Time(s)
magman
PostPosted: Sun Feb 12, 2012 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another completed build to add to my system. This time it's a Thomas Henry SN-Voice.
This was probably the second module I built, probably over 2 years ago, but it has been hiding in a corner as I couldn't get it to work.
At first I thought it was a duff SN76477 chip, as this is one I bought over 20 years ago and has been languishing in my garage for years. This proved to not be the case, as I've now got a couple more of these chips. But in this new drive of mine to get some modules finished, I found I had wired up one connector completely back to front. A bit of work with a pointed tool to release the pins, stretch a couple of wires then put them back in the right way round rewarded me with a working module.
Since I initially built this module, I've found that I don't like the Omeg pots I originally used, so will probably swap these out in the near future, but I'll play with the module for a while first and spend the time getting some more modules working instead.
That's one more module down, only another 41 to go.
Magman
SN-Voice with Bridechamber panel
 Filesize:  447.11 KB
 Viewed:  238 Time(s)
SN-Voice Wiring
 Filesize:  458.06 KB
 Viewed:  217 Time(s)
magman
PostPosted: Sun Feb 12, 2012 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Time for my first build of 2012 where the bulk of the components were bought in 2012.
This is an Oakley PSU2 +/- 15V PSU which uses a Yamaha PA-30 external power lump, which greatly simplifies the case building (No mains, earthing or transformers to worry about).
The cases are some neat 5U rack cases I found via eBay, here:
All Metal Parts on eBay
The 3U aluminium panels and 2U ventilated panels came from the same source.
If things go according to plan this year, I'm likely to use another 10 (5 pairs) of these cases to house the rest of my 5U modules, plus a couple of 6U cases for my Formant build.
On to my next module build now, to start filling out these cases.
Regards
Magman
Two new 5U cases with Built in Oakley PSU.
 Filesize:  374.54 KB
 Viewed:  240 Time(s)
A bit more detail of the PSU and distribution boards
 Filesize:  427.35 KB
 Viewed:  224 Time(s)
A rear view, showing the connection between the two racks and the tidy rear panels.
 Filesize:  474.15 KB
 Viewed:  246 Time(s)
magman
PostPosted: Sun Feb 12, 2012 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
210 One more completed module to add to my synth.
This time its a Juergen Haible Tau "Pipe" Phaser that I've had for a couple of years but I've finally got it working.
This module gave me a load of problems in recent days. After initial testing, I found a few pots I had reversed the wiring of. After fixing this and putting it back on test, Magic Smoke came out of the PSU of my main system (An R3 PSU from Farnell which appears to have piss-poor short circuit protection). Being totally pissed off, it was a couple of days before I got round to fixing the blown PSU (I finished one of my other PSU's instead, an Oakley PSU2, just in case).
When everything was back up and working, I found that it was this module that had gone faulty - with a short on the +15V rail. I had originally built this module with a couple of 10uF Tantalum caps on the PSU rails, so I immediately suspected these parts (one of the failure modes for Tantalum caps is unfortunately a dead short). Binning the Tantalum caps meant everything was hunky-dory again.
Incidentally, this version of the module has been built with SSM2210 transistor pairs. Given the Bridechamber currently sells these chips for $10 each, there are some $200 of these chips on this board alone. Not an inexpensive module.
Regards
Magman
JH Tau Phaser with Bridechamber panel.
 Filesize:  428.15 KB
 Viewed:  222 Time(s)
Wiring details and all those SSM2210 chips.
 Filesize:  441.08 KB
 Viewed:  227 Time(s)
magman
PostPosted: Sun Feb 12, 2012 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
My next pair of builds to be completed were a pair of Ryk M-185 sequencers. But I've already posted some pictures for these on the M-185 thread, here:
http://electro-music.com/forum/post-353869.html#353869
Regards
Magman
magman
PostPosted: Sun Feb 12, 2012 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
My latest module brings me pretty much up to date - this time an Oakley EFG (Envelope Follower/Gate)
I actually won the front panel for this at the UK Synth-DIY raffle in 2009, so it's been one of the longest duration builds in my work stack. It has actually been built for ages, I just needed to get round to testing it.
Working nicely now though.
Regards
Magman
Oakley Envelope Follower Gate.
 Filesize:  381.79 KB
 Viewed:  198 Time(s)
More wiring details.
 Filesize:  395.36 KB
 Viewed:  218 Time(s)
Audio files: 140
PostPosted: Mon Feb 13, 2012 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Magman, you have been very busy. Great stuff. You do great work. Thanks for keeping us posted on your activities. Now we need to hear some music.
seaweedfactory
PostPosted: Mon Feb 13, 2012 11:19 am    Post subject: . Reply with quote  Mark this post and the followings unread
Audio files: 550
PostPosted: Mon Feb 13, 2012 1:13 pm    Post subject: Re: 40106 Microsynth Reply with quote  Mark this post and the followings unread
seaweedfactory wrote:
Here's a really simple (and small!) 40106 microsynth.
sounds great, nice chopper sounds at the start Very Happy
makes me want to build it right away, but with half of the 40106 unused
right now I probably get carried away modding it, so I'll leave it for some
other time.
nice thingy!
Audio files: 31
PostPosted: Wed Feb 15, 2012 3:17 pm    Post subject: First build for 2012
Subject description: A new CGS Infinite Melody w/ Diatonic Converter
Hi everyone!
Looks like the DIY community is off to a great start in 2012. Enjoy the looks and the sounds!
I just finished a CGS Infinite Melody and Diatonic Converter and managed to fit it onto a single-width (3x9") Aries-style panel.
Very interesting module, too -- it all came to life on the first power-up however took me awhile to calibrate the diatonic converter.
CGS Infinite Melody/Diatonic Converter. This view shows the Infinite Melody PCB.
 Filesize:  1.03 MB
 Viewed:  213 Time(s)
frequencycentral
PostPosted: Fri Feb 17, 2012 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.frequencycentral.co.uk/
