2012 Build Pictures
Page 12 of 16 [384 Posts]
Goto page: Previous 1, 2, 3, ..., 10, 11, 12, 13, 14, 15, 16 Next
egasimus
PostPosted: Sun Sep 09, 2012 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
bubzy wrote:
bubzy wrote:
fonik wrote:
65mph? wow!
ah, the magic of fooling sensors Very Happy
But you didn't get very far Laughing
i fell off :/
hahaha you win Laughing
Boogdish
PostPosted: Sun Sep 09, 2012 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
The sound quality from my camera is TERRIBLE, but this module only does control signals.
This is a prototype I finished yesterday, it's a voltage to rhythm converter. It does an ADC on an input voltage and uses the binary result as an 8 beat pattern. 8 different outputs can each correspond to a different sample, or it can be put in parallel mode and each output corresponds to a certain bit of the same sample. It can output triggers or gates, has a built in clock or can run off an external clock. I've had a lot of fun with it over the last couple of days!
PostPosted: Tue Sep 11, 2012 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
The Clockbox... not really a soundbox, this is more of a small utility device for making breadboarding Lunetta test circuits simpler. I thought it was kindof pretty, so I post it here.
I got tired of building power sections and clock oscillators over and over, so I built this little box that gives me a regulated and filtered 9V and four square wave clocks. Each oscillator has 3 different range capacitors, so the box can produce frequencies ranging from about 0.01 Hz to 6300 Hz overall. With some alligator clips and/or wires into the salvaged speaker terminals, I can plug it into my breadboard and away I go!
Despite careful planning of some stuff, I didn't realize that all this stuff in such a small box would barely fit... in fact, I had to glue the thing shut... hopefully I'll never have to get in there to fix anything! Oh well, each build is a learning experience....
James.
The Clockbox
 Filesize:  186.43 KB
 Viewed:  137 Time(s)
PostPosted: Tue Sep 11, 2012 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice. I like the salvaged speaker connectors.
davebr
PostPosted: Wed Sep 12, 2012 8:44 pm    Post subject: 2012 Build Pictures
Subject description: Modularsynthesis.com
I built a half a dozen modules including:
5U E340 Cloud Generator
5U E350 Morphing Terrarium
Threeler Third Order VCF
Buchla Pulser - Crossfader - Timbre Generator
Tap Tempo LFO
XY CV controlled Laser
Links to the various projects are at the Quick Links at http://modularsynthesis.com/
bubzy
Audio files: 63
PostPosted: Thu Sep 13, 2012 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
wowzers, whats that laser thing?
_Richard_ Smile
davebr
PostPosted: Thu Sep 13, 2012 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
http://modularsynthesis.com/modules/DJB-laser/laser.htm
Inventor
Audio files: 267
PostPosted: Thu Sep 13, 2012 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
RingMad, your box building skills are improving! Great little utility box you got there, not unlike my emSynth clock modules in purpose though totally different in form. And hey, diversity is our strength, right? Rock on RingMad!!!
Les
Audio files: 579
PostPosted: Thu Sep 13, 2012 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah that's a neat idea. I've made some simple oscillators for testing a while back, but it's just on a piece
of perf with trimpots and I think I have some of those speaker connectors somewhere Laughing
(allthough I also am still thinking about a complete 'workstation')
earlier this year I finished 2 more synth cases and painted all of them, so here's a photo of those. Cool
DIY synths
 Filesize:  99.34 KB
 Viewed:  458 Time(s)
Audio files: 579
PostPosted: Thu Sep 13, 2012 3:17 pm    Post subject: WogglebugXL Reply with quote  Mark this post and the followings unread
..,and yesterday I finished my WogglebugXL Very Happy It's based on Richard Brewster's version, with some extra in- & outputs
and adjusted to -5/+5V levels, except for the clk rate CV, which is now buggin me a bit (you get it 'buggin' , sorry that was really bad)
so i'll probably change that sometime.
 Filesize:  93.83 KB
 Viewed:  408 Time(s)
 Filesize:  40.22 KB
 Viewed:  400 Time(s)
 Filesize:  63 KB
 Viewed:  415 Time(s)
wmonk
PostPosted: Thu Sep 13, 2012 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, lots of cool projects out here! Does give me some feelin to start again myself, after a few months.
Your boxes look amazing Phobos! Very Happy
Weblog!
PostPosted: Thu Sep 13, 2012 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Amazing work Phobos!
JacobWatters.com
Boogdish
PostPosted: Thu Sep 13, 2012 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
That looks rad, Phobos. I like the blue transformer.
Inventor
Audio files: 267
PostPosted: Thu Sep 13, 2012 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a look at the second emSynth test circuit that I have built. It has three oscillators in the background and two ringmods in the foreground, plust a stereo out at left. See www.emsynth.com for details.
Les
 Filesize:  164.23 KB
 Viewed:  394 Time(s)
PostPosted: Fri Sep 14, 2012 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks folks. Yeah, the speaker connectors... I was originally going to use bolts, like I've done on 2 other boxes, but it would have forced me to use alligator clips only. And then I realized that hardware already existed for this situation, and would allow using gators or wires. To the salvage box!
I'm happy about the dark metallic green-blue paint job, although it was really hard to photograph accurately.
PHoBos: You're a monster! So prolific with the great-looking boxes!
davebr: That laser thing looks amazing!
Les: Rock on! I don't know how you do it, soldering that tiny stuff! Do you use one of those magnifying lamps? At my age, I'm having trouble seeing close now.
James.
Inventor
Audio files: 267
PostPosted: Fri Sep 14, 2012 5:11 am    Post subject: Reply with quote  Mark this post and the followings unread
James, I am one of those strongly nearsighted people (20/400 vision) that is somewhat blessed or fortunate in that without glasses I see tiny objects with great clarity - if they are positioned about 4" to 12" from my eyes.
Naturally, soldering without safety glasses is a concern so I plan to get some type of clear or slightly magnifying glasses if only for safety's sake.
And the tiny parts are not that amazingly tiny, I was soldering 0805 and SOIC parts in the late '80s and early `90s when I was working. The tiniest thing I ever soldered was an 8-bump 555 flip chip, to which I soldered a wire to one corner pin. At this stage in life, though, I don't think I'd feel safe soldering anything smaller than 0805 discretes and SOIC chips.
But you know what? those modules really save a LOT of space!I I didn't realize that 50% to 75% space savings depending on the board adds up to SO MUCH circuit density! Plus they are so easy to wire up. We'll, I should stop this for being accused of selling all the time, but hey, I'm proud of my little creations.
See ya round the forum,
Les
Audio files: 579
PostPosted: Sat Sep 15, 2012 2:21 pm    Post subject: plastic scratchtastic Reply with quote  Mark this post and the followings unread
thanks
here's something I build today (ok i started yesterday evening), a credit card scratch machine
made from an old portable cassetteplayer. I had seen this idea a couple times before before but
decided to give it a try after seeing it done again in this this video yesterday.
I rewired the motor driver to control the LED, so that it lights up dim when you turn it on, and shines brighter
when you move the card.
not sure yet if I will paint/stain it or maybe add some simple markings.
 Filesize:  45.45 KB
 Viewed:  418 Time(s)
 Filesize:  60.01 KB
 Viewed:  420 Time(s)
 Filesize:  51.06 KB
 Viewed:  406 Time(s)
PostPosted: Sat Sep 15, 2012 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
skimming Shocked Cool
Audio files: 579
PostPosted: Sat Sep 15, 2012 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
LOL,. it would be nice if they used that for a musical purpose, imagine a couple of ATM machine's broadcasted live Wink
LektroiD
PostPosted: Tue Sep 18, 2012 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the story so far; Suitcase Synth and the Behemoth. Just a few more modules to go...
LEKTROID STUDIO
 Filesize:  2.16 MB
 Viewed:  410 Time(s)
LektroiD
ashleym
PostPosted: Wed Sep 19, 2012 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I love these. I am into the idea of panels/plates of synth stuff- the Serge type of idea. Bundle a few items, use mid sized (ie not one slot per VCO or a complete 19") panels and Robert is your father's brother. I took some photos of mine but I realised I shouldnt be let lose with a jigsaw.........
Perhaps a thread could be what do you put in a panel? I am banana based so mixing is a little different. How about 3 filters and a couple of mixers- one for mods and one for audio (OK 3 mixers might work better but bananas can get round this). Or a panel of ENV and LFOs with a matrix mixer?
ashleym
PostPosted: Wed Sep 19, 2012 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a few modules, eh? what are the chances of that???
Brilliant looking set up. We both use a 101 as a controller keyboard/simple synth. Tidy looking studio. I find a tidy studio really helps my head with creativity, trouble is I dont have one- tidy studio that is, I have a head.
Judging by your great music the Behemoth is being put to good use. Thanks for sharing, a continuing inspiration.
ashleym
PostPosted: Wed Sep 19, 2012 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry if I sound like a bit of a tw@t saying "great for you doing this, BUT I have.....". It just came out a bit wrong
dougseidel
PostPosted: Wed Sep 19, 2012 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
just a 3x3 matrix mixer. with zebrawood knobs, which i thought came out cool.
 Filesize:  609.28 KB
 Viewed:  411 Time(s)
http://dougseidel/tumblr.com
loydb
PostPosted: Thu Sep 20, 2012 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I like the woodwork! How did you attach those wooden knobs to the pot shafts? I've thought about making glass knobs for a build, but cannot think of a secure way to attach them other than glue, which would definitely make it hard to maintain...
