Roland JD800 keyboard removing glue
dancelwerk
PostPosted: Fri Jan 13, 2012 1:00 pm    Post subject: Roland JD800 keyboard removing glue Reply with quote  Mark this post and the followings unread
Hi to all, if you are owner of a JD800 and have the problem of the glue, you can remove from the keys in a simple way, ok the glue makes liquid at 38º C, ok put the keys in a hot water, and metals sticks of the keys go out, after you have to put the keys for an hours in bleach, and glue dissapear, wash with water, and voila!!!.
is fantastic, and simple.
i hope you enjoy.
Dancelwerk.
