  Twyndyllyngs Live Chez Mosc
Dual Vca Veroboard or pcb
Page 1 of 1 [4 Posts]
squarewhite
PostPosted: Thu Oct 04, 2012 5:29 am    Post subject: Dual Vca Veroboard or pcb Reply with quote  Mark this post and the followings unread
Hi
anyone selling a dual vca pcb or have any stripboard layout for a dual vca?
thanks in advance
best
vladosh
PostPosted: Thu Oct 04, 2012 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
greetings squarewhite ,you can try my dual vca layout if you can find one of these veroboards ,it is a working layout ,tested and all ,the boards btw you can find on ebay under - special vero board
here's the layout link http://electro-music.com/forum/topic-50460.html
squarewhite
PostPosted: Fri Oct 05, 2012 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks vladosh for the link.
the holes on before and after the 'e' are the bc560?
does (-) means -15 volts or gnd? sorry if this sounds stupid, but this is my first perf board version for the modular.
vladosh
PostPosted: Sat Oct 06, 2012 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
hi squarewhite
yes the holes are for transistors BC560C ,it goes like E-B-C in my layout ,E - stands for Emiter and the - is - 15 ,actually mine works on - 12 ,but should be no problem ,good luck with it
there is one jumper there that serve nothing really,the ones in the far left but you got the idea i guess
cheers
Vlad
