Ensoniq EPS
alieneYe
PostPosted: Sat May 26, 2012 6:17 am    Post subject: Ensoniq EPS
Subject description: ? about OEX-8
hello there,
i just picked up an old ensoniq EPS sampler.
i'm wondering if anyone here has one and has the OEX-8 output expander for it. if so has anyone ever opened the OEX-8 up to see what was inside? any electronics or is it just a box with 8 1/4" jacks that all share the same ground?
i'm looking to perhaps build one for my eps. i notice that it comes from a DB9 connector so i'm wondering if one of those pins is ground and the other 8 are the solo outputs.
i have not yet tried to meter that connector yet, thought i would ask here and see if anyone had any info
thanks for any help i can get
t
cappy2112
PostPosted: Mon Jun 03, 2013 9:23 pm    Post subject: Re: Ensoniq EPS
alieneYe wrote:
hello there,
t
CHeck with Sam Mims from Syntaur Systems, and/or Garth Hjelte from Rubber Chicken. They both support(ed) Ensoniq samplers are one time.
istel
PostPosted: Sun Jun 07, 2015 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
pretty sure its not just a breakout box as simple as that - at least i know the output expander for the ASR-10 is somesort of multiplexed digital signal that the box translates and outputs.. in the manual it clearly says that it is /not/ just jacks wired to a funky DIN plug
not sure it applies to the EPS, but they are kinda similar
