  Antimon Antimon Waves
Suboctave Oscilator (by Roman Sowa)
vladosh
PostPosted: Fri Jun 22, 2012 11:42 am    Post subject: Suboctave Oscilator (by Roman Sowa) Reply with quote  Mark this post and the followings unread
Here's a stripboard layout for the suboctave oscillator / clock divider by Roman Sowa link:http://www.sowa.synth.net/modular/divider.html , i'll be building it this coming week or so and i always check the layout while stuffing but seems ok to me so far..
cheers
you may also add decoupling electrolits on the power rails ,i missed it cause it was obvious to make,also the 120K resistors can be soldered on the pots themselves
(edit: found an error ,seems ok now)
(edit: the fix that i thought i made was an error ,should be ok now)
 Filesize:  207.95 KB
 Viewed:  213 Time(s)
Audio files: 129
PostPosted: Mon Jun 25, 2012 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Roman's frequency divider is a good circuit and works well , i built a quad version with 2 outs per divider in 2009 i think Smile, i mostly use the even division , but the 1.5 & 3 is cool too Smile .
a great circuit .
epicyclus@skrogmusic.plus.com
vladosh
PostPosted: Mon Jun 25, 2012 8:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dave ,you sugested this to me i think ,and that 2 outs per division is great idea ,i still haven't build it ,that way i can use it also with clocks low freq ,may modify it in meantime
Vlad
