Testing MIDI IN
PostPosted: Tue Jul 03, 2012 6:45 pm    Post subject: Testing MIDI IN Reply with quote  Mark this post and the followings unread
While exploring my arduino last summer, I wrote a little sketch to test whether or not I was correctly receiving midi in by echoing that data to the console in the arduino's programming environment. I haven't tested it this year, but it should help others do the same.
I used the Arduino Mega 2560, which has 4 serial I/O ports. Also, the pins might be different from other arduinos.
 MIDI IN test
 This sketch is an attempt to read midi in and display it.
 This is one step in the process of creating an arduino-based midi router/processor/arpeggiator.
 started 05 Aug 2011
 modified
 by Dr. Steve [aka MusicMan11712]
 // MIDI IN Buffer [as an array]
int MidiDataBuffer [256];
 // Buffer Pointers [as indexes]
unsigned char WritePointer = 0;
unsigned char ReadPointer = 0;
byte WP = 0;
byte RP = 0;
 // Incoming Data
int IncomingByte = 0;         // incoming serial byte
 // SETUP
void setup() {
  //  Set MIDI baud rate:
  Serial1.begin(31250);
  Serial.begin(9600);
  // Clear MidiDataBuffer and reset write/read pointers
  for (int n=0; n<256> 0) {
    // get incoming byte:
    IncomingByte = Serial1.read();
   Serial.println (IncomingByte,HEX);
void establishContact() {
  while (Serial.available() <= 0) {
    Serial.println("0,0,0");   // send an initial string
    delay(300);
PostPosted: Tue Jul 03, 2012 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Mega (or some model with multiple serial ports) is really your best bet here for doing MIDI development. I did a lot of work with an uno equivalent (started out as the Mintduino breadboard kit, and ended up soldered into a small protoboard), and i beat my head on MIDI stuff until I got the Mega.
Some of my experiences got written up here:
http://electro-music.com/forum/topic-52722.html
PostPosted: Wed Jul 04, 2012 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for chiming in on this and for posting the link to the thread with your comments--useful info there. I realized after I posted the midi in test code that it wouldn't work on a single UART Arduino since midi needs one serial connection and communication with the serial monitor needs another. (I chose the Mega 2560 specifically because it had 4 UARTs.)
Like you, for midi I/O I used an old joystick to midi cable. I didn't take it apart, though.
Steve
