The Casioduino Project - Understanding the Keyboard Matrix
Page 1 of 1 [6 Posts]
PostPosted: Tue Jul 17, 2012 6:15 am    Post subject: The Casioduino Project - Understanding the Keyboard Matrix Reply with quote  Mark this post and the followings unread
Last summer I started getting into Arduino midi programming with some simple midi in and midi out sketches.
This summer, I was throwing out a dead Casio CT-615 [non-midi] keyboard which my sons had talked me into buying at a neighborhood sale. After I took it apart, I noticed that the insides looked like something had been spilt on it. I had no desire to try to fix it, but began to take it apart just to see how it worked. Thus, the idea of the Casioduino was born.
The first task was to figure out how 61 keys came out of 17 leads on a ribbon cable. So I learned about keyboard matrixing (there are 10 groups of 6 keys each plus one group with the top C) and adapted an Arduino sketch written using a KeyPad library from Wiring.
Here are some of the resources on understanding the keyboard matrix I found useful.
2015-09-05: I mentioned the Casioduino experiment in chat and thought I'd double check the links. One or more are deal; a few point to different things than they did three years ago and/or to a missing document. At the moment I am notating those. The plan is to edit them out, fix them, or find other links later. Most of the links do work and most of the ones that do have relevant material. --Steve
1. DEAD LINK: http://www.rtbot.net/Keyboard_matrix_circuit [brief, easy-to-understand overview]
2. LINK WORKS: http://www.dribin.org/dave/keyboard/one_html/ [detailed, easy-to-understand explanation; includes explanation of the use of diodes] 2015 note: simple enough for novice builders like me!!!
3. http://arduino.cc/playground/Code/Keypad [Arduino Keypad Library; link to tutorial]
4. SITE MOVED*: http://home.roadrunner.com/~jgglatt/hardware/key.htm [using PIC16C84; includes schematic; uses 74LS138 (mux)] *2015 note: I either have an updated link or re-hosted site for jglatt's site; will look for this specific page and repost link if I find it
5. LINK WORKS: http://wiring.org.co/learning/ [host site for KeyPad and other libraries and sketches]
6. LINK WORKS: http://weltenschule.de/TableHooters/Casio_MT-540.html [circuit-bending resource for MT-540 (tone bank) with comments about many other Casio models] 2015 note: detailed info for Casios!!
7. LINK WORKS: http://weltenschule.de/TableHooters/ [host site for "warranty void" with circuit-bending details for a number of keyboards] 2015 note: detailed info for Casios!
8. LINK WORKS: http://generror.wordpress.com/2010/07/08/history-of-casio-keyboards-2/ [non-tech historical explanation of Casio keyboards & features]
9. LINK WORKS: http://arduino.cc/forum/forums.html/topic,60248.0.html [Arduino Forum discussion; has some insights]
Highly Liquid has their own MIDI CPU board (among other products). Their explanations, schematics, etc. can be applied to Arduinos and others.
10. http://highlyliquid.com/hl2012/blog/52 [“The Keyboard Matrix Explained”]
11. http://forum.highlyliquid.com/showthread.php?t=724&goto=nextnewest [connection for using 1 MIDI CPU with 2 61-key matrices]
12. http://forum.highlyliquid.com/showthread.php?t=716&goto=nextnewest [connection for using 1 MIDI CPU with 128 switches]
13. DEAD PDF - possibly moved? http://highlyliquid.com/support/docs/pdf/MIDI-CPU-Hardware-Rev-K.pdf [also shows hookups for rotary encoders among others]
I hope these links are helpful. Thanks to PHOBoS and Cyno for pointing me to a number of these links.
Steve
PS: I have numbered the links. If you find that any of them no longer seem to work, send me a PM with the number of the link(s) and either the name of this thread or a link to it. Thanks.
PPS: Here is another insightful link posted by richardc64 in another DYI thread.
14. LINK WORKS http://pcbheaven.com/wikipages/How_Key_Matrices_Works/ from "Cheap Keyboard --> sequencer" - http://www.electro-music.com/forum/post-365817.html#365817
PostPosted: Tue Jul 17, 2012 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you have a link to the sketch or your project? This sounds very interesting, and that set of links very useful.
PostPosted: Tue Jul 17, 2012 8:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
elmegil wrote:
Do you have a link to the sketch or your project? This sounds very interesting, and that set of links very useful. Thanks!
For what its worth, here's the code so far. When I get around to putting in a midi out (or two), I will simply change the text going to the console to midi out data. The Casio has a volume slider. Since the keyboard is not velocity sensitive (the keys are just switches), I might try using the volume slider to set velocity of note ons.
Steve
// Based on the KeyPad library (See CustomKeypad.pde.)
// Mods for testing Casioduino by Dr. Steve 9 July 2012
// His son Avi also contributed.
/* Coded for Casio CT-815 keyboard using 10 sets [rows] of 6 keys [columns] each.
C, C# D, Eb, E, F
F#, G, G#, A, Bb
etc.
The keyboard matrix comes out via 17 leads
(10 rows + 6 columns, plus 1 row for top C --not used here)
See RowPins and ColPins for connection of the Casio keyboard matrix
leads into the Arduino. For this test of the connection,
I started with pin 31 of the Mega 2560 and used the Casio leads
in order (from 1 to 16).
#include <Keypad.h>
const byte ROWS = 10; //ten rows
const byte COLS = 6; //6 columns
char keys[ROWS][COLS] = {
  {1,2,3,4,5,6},
  {7,8,9,10,11,12},
  {13,14,15,16,17,18},
  {19,20,21,22,23,24},
  {25,26,27,28,29,30},
  {31,32,33,34,35,36},
  {37,38,39,40,41,42},
  {43,44,45,46,47,48},
  {49,50,51,52,53,54},
  {55,56,57,58,59,60},
byte rowPins[ROWS] = {31, 32, 33, 34, 35, 42, 43, 44, 45, 46 }; //connect to the row pinouts of the keypad
byte colPins[COLS] = {36, 37, 38, 39, 40, 41}; //connect to the column pinouts of the keypad
byte CasioduinoKey = 0;
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
  Serial.begin(9600);
  keypad.setDebounceTime(0);
  keypad.setHoldTime(100000);
  Serial.println("You may now start.");
void loop(){
  keypad.getKeys();
  if(1)
    for(int n=0;n<LIST_MAX;n++)
      char key = keypad.key[n].kchar;
      CasioduinoKey = byte(key);
      if(key != NO_KEY && keypad.key[n].stateChanged)
      if((keypad.key[n].kstate!=IDLE) && (keypad.key[n].kstate!=HOLD))
//    if (key != NO_KEY)
//        Serial.print(key);
        Serial.print("Casioduino Key # ");
        Serial.print(CasioduinoKey);
          if(keypad.key[n].kstate==PRESSED)Serial.println(" was pressed");
          if(keypad.key[n].kstate==RELEASED)Serial.println(" was released");
          delay(10);
PostPosted: Tue Jul 17, 2012 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a sample of the output that is sent as text. Thanks to help from Jan and Scott, I used PuTTY instead of the Arduino IDE's built-in serial monitor.
PostPosted: Wed Jul 18, 2012 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for putting all the links in one place Steve. This will help when i get around to doing something similar.
JacobWatters.com
PostPosted: Tue Jul 31, 2012 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Steve. I just came across this and thought it might be useful to you.
http://arduino.cc/forum/forums.html/topic,57211.0.html
JacobWatters.com
