NeinOhNine -- a 909 kick drum clone you can build
Page 1 of 1 [23 Posts]
HexInverter
PostPosted: Sun Aug 12, 2012 9:07 pm    Post subject: NeinOhNine -- a 909 kick drum clone you can build
Subject description: Yup, and this one should actually work ;)
Hey guys Smile
Been living over at the Muff's forums for awhile...things seems to have slowed down a bit here, so I've just been going with the flow!
Circuit boards and rare transistor sets are now in stock!
http://shop.hexinverter.net/product.php?id_product=22
Anyhow, I'm just popping in to drum up some interest for a PCB I will have available for folks to DIY with in the not-too-distant future. Here is my post about it:
When I sought out to make a DIY 909 kick drum for my modular, I naturally stumbled across a thread over on Muff's where people were pulling their hair out trying to get some designs others have posted on the 'net working.
It seems to me that there is no easy solution...you can build a 9090, but that's the whole 909. I just want a kick drum module, myself (well, and maybe a clap and snare down the road...)
The general consensus is that none of the PCBs others have made work like they should. Also, none of them have the crucial noise generating circuitry. For some strange reason, they just did not include it.
Anyhow, I'm currently laying out the PCB for a 909 kick clone.
I will be converting component values so it can run from +/-12V and still sound proper. It will also natively support +/-15V like the original.
I will be getting some boards made for myself so was wondering if anyone else would like some as well!
They will be double-sided boards, easy to follow and feature some handy build documentation. I will be providing a Mouser project cart and a BOM to help people get parts easily.
Let me know if you are interested. I'm not taking preorder money but I will keep a running tally so I know how many boards to order, so please let me know if you are interested!
I will be posting sound/video when I prototype.
The board is presently routed and just has to be prototyped, then later, ordered.
There are holes for original 2SA/2SC series transistors if you want to go the rare component route. Otherwise, you can use common BC series transistors.
The board has space for either:
1.) The original Roland CD4006-based noise circuitry
or
2.) a PIC-based 3 component setup that should (in theory) sound the same (tests to come).
...and the regions bounding these parts are clearly labelled.
This is the only diversion from the original circuitry -- the addition of an alternative noise source.
I will have some PICs on hand if folks want one preprogrammed with my noise code programmed into it. I modelled the code to work the same way as the original CD4006 noise generator. White noise is created via a 32bit linear function shift register internally on the PIC -- on the Roland design, it is achieved by two cascaded CD4006s and an XOR gate, instead of in code.
Here is a quick rendering before ground planes and silk-screen is added:
 Filesize:  108.8 KB
 Viewed:  126 Time(s)
hexinverter.net -- Shop DIY projects and modules for modular synthesis
sympleSEQ -- the simple to build analog step-sequencer
seqSQUARED -- the Analogue Pattern Generator
--> Put yourself on the hexinverter.net mailing list to be notified when in stock!
HexInverter
PostPosted: Sun Aug 12, 2012 9:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah yeah, forgot to mention --
If you would like to be notified via email when I have PCBs in stock, throw your email on my mailing list. Don't worry, I only ever send product stock notices, so, there is no worry of spam:
http://blog.hexinverter.net/?page_id=14
HexInverter
PostPosted: Fri Aug 24, 2012 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really chugging along on this! I expect to have PCBs ordered by the end of the weekend! Yipee.
Crappy video is here! Recorded sound samples to come...
http://www.youtube.com/watch?v=JIjwB0PEwoI
SineSurfer
PostPosted: Fri Aug 24, 2012 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi there, definitely interested in 1 pcb, but this would seal the deal ->"and maybe a clap and snare down the road" hehee.
The video sounds promising Wink
Freddy, riding the wave!
http://www.hakkenmusic.blogspot.com
HexInverter
PostPosted: Fri Aug 24, 2012 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right on man Smile Glad to have ya on board.
I am also adding an (optional) opamp for buffered output of the noise generator signal -- so, in the future, if I make more of the 909 voices, you don't have to repeat the noise section on each module -- you can then just chain it to the different voices (since almost all of the 909 drums use the signal at some point). The noise section is the only area with some annoying parts in it...the CD4006s are discontinued now. While not hard to find, the NTE replacement at Mouser is $3/pc so it saves ya $6 or so per module if I make more of 'em! Very Happy
HexInverter
PostPosted: Fri Aug 24, 2012 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sound samples Smile
Keep in mind it is running on +/-12V when it should be on 15V. I will need to adjust component values, then it will sound a lot cleaner (less noise once the amplitudes are corrected) as well as the controls working better.
Nein! Ohhh, nein! -- a DIY 909 kick drum clone by hexinverter.net
HexInverter
PostPosted: Sun Aug 26, 2012 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Renderings before going to the board house tonight Very Happy
delayed
PostPosted: Mon Aug 27, 2012 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
what do you think pricing will be? what are the 2sa/2sc numbers? and are they subbed with bc557/547?
thanks,
HexInverter
PostPosted: Mon Aug 27, 2012 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks,
2SA and 2SC are rare original trannies. Their full part numbers are 2SC2603 and 2SA1115. You need 6 of each for one kick.
I will have the rare trannies for sale. $20 for a set of rare transistors to do one kick with.
The modern substitution is BC549 and BC559.
PCBs will be $25 each. It is a 98x98mm PCB so is quite the bit of surface area.
HexInverter
PostPosted: Fri Sep 14, 2012 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Fri Sep 14, 2012 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Silly question regarding transistors and subs...
How does one decide on what's a good sub? I know there are some factors (voltage ratings, HFE/beta values, etc) that you can map to rough equivalents, but it seems that most of the general purpose NPN / PNP transistors out there have similar specs?
I just built an 808 kick stripboard from one of the other forum posts here, and it called for BC546 & BC556 per the Eric Archer clone circuit. I didn't have any, so I subbed BC547 and BC557 and I can't really tell the difference between how mine sounds and how samples of the others sound.
I see here you're recommending the 549/559 transistors....why did you pick those?
At some point soon I plan to sub in 2N3904's and see if the sound is any different Smile And I have 546's on order (was supposed to have 556's as well, but, I'll have to take care of that another time Smile )
HexInverter
PostPosted: Fri Sep 14, 2012 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
The ones used were selected simply for their low noise characteristics Smile That's pretty much it.
You're never going to get the exact same other specifications as the original transistors, so pretty much anything will give good results -- just, maybe not identical, is all!
HexInverter
PostPosted: Sat Sep 15, 2012 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Test build in progress!
HexInverter
PostPosted: Sat Sep 15, 2012 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD
PostPosted: Sat Sep 15, 2012 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I would have, but $49 shipping to the UK is outrageous.
Anyone in the UK up for a group buy?
LektroiD
HexInverter
PostPosted: Sat Sep 15, 2012 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey man,
Yes, it is outrageous. Sad I wish I could do something about this, but Canada Post is going down the shitter and taking its customers with 'em!
What were you trying to order?
It may be that it can be cheaper.
Everything in my shop is priced by cost, because stupid Canada Post only lets me insure up to $100 on cheap shipping services (the jerks!)
I only finally changed my shipping prices after I spent tonnes of money eating the cost myself ($20 here, $10 there, etc...)
Usually with PCBs, it's just fine to send over $100 worth of them as lettermail, because lettermail seldom gets lost. It's the small packet stuff that gets lost a lot and I wind up paying out of my pocket for reimbursements for!
Send me a PM and we'll work it out for ya.
LektroiD
PostPosted: Sat Sep 15, 2012 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey man,
I was just after 1x NeinOhNein Kick with transistors, total $88 makes it prohibitively expensive. I don't care for insurance, tracked, or signed for if it's going to triple price of a board. Send it 2nd class basic rate for all I care, even if it takes a month to arrive, I'd rather wait patiently than empty my bank account.
...Or maybe we can get a group buy going in the UK. Anyone in?
LektroiD
HexInverter
PostPosted: Sat Sep 15, 2012 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
Hey man,
Hmm...are you sure there was not another shipping option offered? Shipping is more like $8 for that to go in a bubble mailer, as it can go lettermail no problem (and be there in just a couple of weeks, to boot). It shouldn't be your only shipping option...that's express shipping with tracking!
If you're sure there was no other shipping option, it must be that something's wrong in my shipping software that I've not yet noticed. If you wouldn't mind bearing with me I will try and see what's up in my shop's back end.
HexInverter
PostPosted: Sat Sep 15, 2012 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
It looks like you have it in your cart with cheap shipping selected, unless I am mistaken? Let me know if it's still giving you problems and you can just send me a direct PayPal payment.
Everything looks fine in my shop backend at the moment as far as this goes :0
LektroiD
PostPosted: Sat Sep 15, 2012 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
It starts off with the basic $3 shipping, but when I get to the shipping page, it adds $49 to the total.
So how much is the best price you can do shipping for on one 909 kick PCB + transistors?
LektroiD
HexInverter
PostPosted: Sat Sep 15, 2012 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting...and there is no other option for shipping options? I just shipped more than that to Belgium for $10...
Shipping will be $8 to the UK, so, $47 total for the PCB + rare transistors. You can PayPal directly at: hex [at] hexinverter.net
Make sure to include your proper shipping address, and to send payment for "goods", not gift or anything Smile
Cheers!
LektroiD
PostPosted: Sat Sep 15, 2012 7:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Paid Smile
What's the chances of a drum sequencer happening in the near future?
LektroiD
HexInverter
PostPosted: Sat Sep 15, 2012 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
Paid Smile
banana Sweet! Will post it with the others on Monday Smile
Yeah, if you ever have any troubles with my shop, feel free to email/message me. Usually it's just a shit bug/error in the web software! I am many things, none of which are a good webmaster! LOL
