  Muied Lumens Frequencies
Differences between G2 1.1 and 1.32
Page 1 of 1 [4 Posts]
BobTheDog
PostPosted: Tue Aug 23, 2005 6:33 am    Post subject: Differences between G2 1.1 and 1.32 Reply with quote  Mark this post and the followings unread
Hi Everyone,
I have the printed 1.1 manual and the 1.32 in pdf and am having difficulty working out what all the changes are between the two versions.
Can anyone point me to some information about what changed between these versions.
All the best
Andy
PostPosted: Tue Aug 23, 2005 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
There's a README.txt that accompanies the Clavia OS update. In there it lists at least all the differences between 1.24 and 1.32.
http://www.clavia.com/G2/V1_32/ReadMe.txt
Maybe look through the 1.24 readme to see differences in 1.10 and 1.32.
1.32 seems very stable, and hasn't "lost" features from older revs, so I'd recommend you use it, especially if you will use patches from electro-music.com Wink
Audio files: 139
PostPosted: Tue Aug 23, 2005 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
To me the biggest or maybe most significant difference is the way the Patch Mode button works on the G2 Keyboard and G2X. What used to happen when you push that is different. Make sure you check it out, unless you have an engine - then I think it doesn't matter.
BobTheDog
PostPosted: Wed Aug 24, 2005 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info,
I am printing out the readmes and will check the patch mode button out.
Thanks
Andy
