Just bought a NMM , are the PC ports MIDI?
Page 1 of 1 [12 Posts]
dude163
PostPosted: Fri Oct 26, 2012 6:34 am    Post subject: Just bought a NMM , are the PC ports MIDI? Reply with quote  Mark this post and the followings unread
Hi all, I got a good deal on a Micromodular so it should be here next week, lots of interesting info here.
Regarding the PC ports on the back, will regular MIDI cables work for that?
Audio files: 216
PostPosted: Fri Oct 26, 2012 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it is MIDI, using normal MIDI cables and a normal MIDI interface on the PC side, the editor is a bit picky on the MIDI interface though.
dude163
PostPosted: Fri Oct 26, 2012 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Any recommended MIDI interfaces? and more importantly any to avoid?
Audio files: 216
PostPosted: Fri Oct 26, 2012 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
currently I use edirol um-3ex, works fine for me with Windows Vista, before that I have used midiman midisport 2x2, that one was OK for me too on both Vista and XP.
Built-in MIDI ports on various audio I/O boxes didn't work too well for me.
dude163
PostPosted: Fri Oct 26, 2012 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK thanks, Ill source out a dedicated midi interface then
looke like my 200 buck purchase is getting higher...
cappy2112
PostPosted: Sun Oct 28, 2012 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
$200 is cheap for a micro modular, you should be happy you got it for that price. $400+ is more common these days.
dude163
PostPosted: Mon Oct 29, 2012 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Im just figuring that out ! I see quite a few for around 350-500 , I also got the wizoo(sp) book and the printed manual too , so Im looking forward to trying it out!
if the editor doesnt work on my desktop ( windows 7) or my laptop ( OSX) Ill convert my netbook to a compatible editing system Smile
dude163
PostPosted: Tue Oct 30, 2012 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Would this one work?
my other devices dont need MIDI to connect to the DAW as they are usb>MIDI
http://www.long-mcquade.com/products/11373/Keyboards/MIDI_Controllers_Drum_Machines/Roland/UM-1_-_1x1_USB_MIDI_Interface.htm
Audio files: 216
PostPosted: Wed Oct 31, 2012 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Guess it would work .. if you would also like a regular MIDI interface for the synth (to play it from the computer for instance) you'd want a double MIDI interface probably.
dude163
PostPosted: Wed Oct 31, 2012 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
OK thanks
Ill look for a 2 or more interface then ,
I appreciate all the help by the way , this forum seems a little deserted , I feel like I missed the party! hahaha
clementshawes
PostPosted: Sat Dec 15, 2012 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm running my Micro' through my Kore 1 controller/interface under Windows 7 (32-bit) using Nord editor v3.03.
The only thing I had to do was set the Nord app to run in Win98 mode and all seems to work well Smile
Ableton Live Suite 9, Max 7
G2DREAM
PostPosted: Sun Dec 16, 2012 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
me too through my korg microkontrol usb midi inteface....
everything is fine.
