female wire harness, pre-stripped?
Page 1 of 1 [6 Posts]
rjd2
PostPosted: Fri Oct 26, 2012 8:28 am    Post subject: female wire harness, pre-stripped?
Subject description: see folks using these. can't find 'em.
hey all, so there are these male pcb connectors that you can solder into a pcb for connecting to panels. example:
http://www.mouser.com/ProductDetail/TE-Connectivity/640456-2/?qs=%2fha2pyFaduhbIktXaNQSh0xBJlCJ75wATtIP6yCJQl0%3d
however, the only female counterpart i can find are the ones that dont have wires connected; they are for crimping. i see pictures of people using what look like pre-made harnesses that have a female connector, about 10" of wire, and a stripped end. does anyone have a mouser part, or link, to these? what do i search for? stripping a bunch of wire is like my least favorite activity; i think i could finish alot more modules if i could just buy those in bulk, and skip all that stripping. thanks, rj
ashleym
PostPosted: Sun Oct 28, 2012 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Have a look here
http://www.muffwiggler.com/forum/topic-69780.html&highlight=
I have ordered up some of the female leads. Are they the sort of thing you were looking for?
rjd2
PostPosted: Sun Oct 28, 2012 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks-close! now imagine that those wiring assemblies had harnesses only on ONE side, not both. if the other side were stripped wire, then that's exactly what i was hoping for.
or, i could just buy pre-stripped lengths, and get to crimping. i just wanna find a way to bypass stripping a bunch of 10" lengths of 22 or 24 wire. something about it makes my fawking brain want to implode.
wmonk
PostPosted: Mon Oct 29, 2012 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Here you go!
http://www.musikding.de/Wire/PCB-connectors:::163_158.html
or
http://www.banzaimusic.com/PCB-Connectors/
Saves a lot of time Smile
Weblog!
rjd2
PostPosted: Mon Oct 29, 2012 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes-thanks!!!
andrewF
PostPosted: Mon Oct 29, 2012 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
just a tip
search on ebay for "dupont 24AWG" This will bring up bulk lots of 25 to 1000 pieces
dupont is the type of connector used all over computers - 1pin, 2pin, 3pin etc
24AWG is a bit thicker wire than the standard 25AWG used in PCs, therefore a bit stronger and can handle being moved and bent around a few more times than the regular PC wire.
