Automations Internally
Lfohead
Audio files: 6
G2 patch files: 28
PostPosted: Thu Nov 01, 2012 2:04 am    Post subject: Automations Internally Reply with quote  Mark this post and the followings unread
How is automations done internally not inside daw..
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Nov 01, 2012 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
As to be expected with the G2, there are infinite ways.
The most straightforward would be to sweep a Control Sequencer with 100% step interpolation ("XFade") by a synchronised, positive going LFO B in "Clk" mode. Depending on the speed settings of the LFO is, the better the automation resolution will be. Eg., by setting the LFO to 64/1, it will sweep the Control Sequencer within 64 bars of music, so each one of the 16 sequencer steps will represent 4 bars, with smooth transitions inbetween -perfect eg. for ambient music. A setting of 16/1 will yield an automation duration of 16 bars, with 1 step per bar. Etc., you get the idea.
Lfohead
Audio files: 6
G2 patch files: 28
PostPosted: Thu Nov 01, 2012 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks alot mate appreciated!
Will sure be put to use!, cant seem to get it sound like the automation by hand inside the daw though, ie on filters.. I made a example with online preview: https://www.box.com/s/tz0d3zyom6fscjso0ml3
I could make it sound the same by automating Filter Pitch%, Sequencer Polarities... But ill end up doing the automation by hand inside the daw again..
Sorry for being pedantic, once again thanks alot
