A bag full of of G2 demo compatible noodle patches
Page 1 of 1 [19 Posts]
PostPosted: Sat Nov 17, 2012 5:15 pm    Post subject:  A bag full of of G2 demo compatible noodle patches Reply with quote  Mark this post and the followings unread
I made the G2 demo compatible noodles that I did in the last two years or so available here.
A lot of these patches will have variations and will listen to CC2 and or notes played, CC119 too sometimes.
These were mostly made to be controlled from what happens in the electro-music chatroom. I made a chat bot for that (hellbo) which translates chat activity into signals for my synths (through MIDI for the G2 and through OSC for the pacarana).
edit: added some 2013 patches.
PostPosted: Sun Nov 18, 2012 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool. Thanks for organizing them into the list of links. Now, where did I put my Nord demo program?
JLS
Audio files: 27
G2 patch files: 278
PostPosted: Sun Nov 18, 2012 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent work many thanks !
Kamil
Sorry my bad English Smile
http://jlswbs.blogspot.com
http://jlswbs.wordpress.com
http://jls.wbs.cz
Audio files: 263
PostPosted: Sun Nov 18, 2012 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
Thanks Smile
PostPosted: Sun Nov 18, 2012 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! Very Happy
[Q]
Audio files: 57
PostPosted: Tue Nov 20, 2012 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
wow.. xmas has come early Very Happy
Thanks Jan.. Smile
cebec
G2 patch files: 31
PostPosted: Wed Nov 21, 2012 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for these!
http://www.soundcloud.com/cebec
dorremifasol
G2 patch files: 49
PostPosted: Wed Nov 21, 2012 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice, thanks Jan!
So Bellbo plays the G2 depending on what happens in the chat room? amazing! Very Happy
Albert
PostPosted: Wed Nov 21, 2012 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hellbo ... played ... I've turned it off for now, but yeah that was what it did.
dorremifasol wrote:
Nice, thanks Jan!
So Bellbo plays the G2 depending on what happens in the chat room? amazing! :D
klangumsetzer
PostPosted: Thu Nov 22, 2012 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah! Cool
btw jan: no complaints from my colleagues the sounds from my office yet.
best regards
eike
make a joyful noise!
https://archive.org/details/EdP024_Antimon_klangumsetzer_rinden_bark
PostPosted: Thu Nov 22, 2012 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
cappy2112
PostPosted: Fri Nov 30, 2012 8:58 pm    Post subject: Re: A bag full of of G2 demo compatible noodle patches Reply with quote  Mark this post and the followings unread
I I made a chat bot for that (hellbo) which translates chat activity into signals for my synths (through MIDI for the G2 and through OSC for the pacarana).
Sounds cool. I'd like to see that.
What is pacarana?
cappy2112
PostPosted: Fri Nov 30, 2012 8:59 pm    Post subject: Re: A bag full of of G2 demo compatible noodle patches Reply with quote  Mark this post and the followings unread
Thanks for the demos.
Any chance you can put a zip file up there to get them all at once?
PostPosted: Sat Dec 01, 2012 4:40 am    Post subject: Re: A bag full of of G2 demo compatible noodle patches Reply with quote  Mark this post and the followings unread
What is pacarana?
http://www.symbolicsound.com/cgi-bin/bin/view/Products/Pacarana
But in reality it is a US army plan to dominate the future world by having a cheap network of computing distributed all over .. anyway .. while the systems are not needed you can make them beep.
As to to zip question ... Wget is your friend ... if anything I probably should upload the patches here instead.
As to the 'see' question .. it's just a bunch of red boxes, a black one, three laptops and and a floortop really ... a bit like ...
and some info about Hellbo.
Them big ears are everywhere Shocked
varice
G2 patch files: 53
PostPosted: Fri Jan 04, 2013 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Jan, thanks for sharing all of these patches Exclamation As usual, much of your work is unique, with “outside of the box” type patching.
A case in point: while checking out these patches, after I loaded the 2011-11-14-01-08 patch and noticed a NoteQuant module named “red->blue”, I realized that this module is not being used at all as a note pitch quantizer. Instead, it is “down converting” a red (96kHZ audio rate) signal to a blue (24kHZ control rate) signal, with the purpose of running the following modules at the slower rate to reduce the patch DSP cycle load. If I had seen this great trick before, I did not remember it Exclamation This is a trick that you have known for a long time already:
http://www.electro-music.com/forum/post-21760.html
A good trick to know indeed Exclamation For example, I can use this trick as an option with my “mono monster” patches (which use up to nine pitch modulated oscillator modules) to significantly reduce the DSP load.
varice
PostPosted: Sat Jan 05, 2013 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Good you discovered it too Cool
And thank you for looking at the patches!
PostPosted: Sat Sep 28, 2013 7:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've added about 50 new ones at http://bluehell.electro-music.com/small_stuff/patches/forums.html - the 2013 ones, newest at top. Again, all are demo compatible.
Enjoy :-)
dasz
G2 patch files: 56
PostPosted: Tue Jun 10, 2014 4:06 pm    Post subject: Re: A bag full of of G2 demo compatible noodle patches Reply with quote  Mark this post and the followings unread
Jan, what are you using the knives and the jar in the photos for? It that to protect the valuables in case of ____ ? I'm being silly, That's a cool setup.
http://www.dasz.com
PostPosted: Tue Jun 10, 2014 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Heh .. those were for making sounds for one of the streaming events here. Not sure when it was exactly.
