unknown function nord rack 2x
Page 1 of 1 [6 Posts]
sontag
PostPosted: Fri Nov 30, 2012 2:16 am    Post subject: unknown function nord rack 2x
Subject description: the unit make anything I think it shouldn't do
I don't know the OS of the unit, I don't know how to see it. The computer OS is win 7. I use cubase 5.
The problem is: when I change a parameter of part D, also change this parameter in part B an C. I read the manual, and I don't find this function.
Thank you very much.
sontag
PostPosted: Sun Dec 02, 2012 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
The function SHIFT+PROGRAM CONTROL if I select C.of the problem solve. The function I suppose is Control Change, that now I can control each part A, B, C, D independently. But the problem now is when I want to record a control change to make an automation in the Daw affect 3 or more parts. Is the unit broke or it is normal?
Roland Kuit
G2 patch files: 127
PostPosted: Mon Dec 03, 2012 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Sontag,
I think you have the slots A-D on the same midi channel. You can change that with the dropdown menue in your editor;
Synth:
Synth settings.
But also within your hardware as stand alone.
sontag
PostPosted: Mon Dec 03, 2012 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
It isn't the same chanel selected in the secuencer, and it's not the same chanel of diferent parts in the clavia nord lead. I don't if you mean this or another thing. What do you mean: "But also within your hardware as stand alone"?
Roland Kuit
G2 patch files: 127
PostPosted: Mon Dec 03, 2012 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
You posted this under the Clavia Nord Modular. So I thought you were talking the NM. Sorry. I don't have a Nord Lead.
PostPosted: Mon Dec 03, 2012 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh, had not seen that before - moved it.
