 Forum index » Artists » Mikronesia
How do you make your music
Audio files: 137
PostPosted: Thu Mar 06, 2003 6:02 pm    Post subject: How do you make your music Reply with quote  Mark this post and the followings unread
Mike,
I've seen you perform a few times now. On stage, you have very little equipment. What do you use to create your music? Is it mostly pre-composed and pre-recorded? Do you use looping playback software? Do you use effects during live performance?
Just curious.
Most musicians have tons of equipment. Being an equipment junkie, I can pretty much figure out their methodology by scoping out their gear.
mikronesia
PostPosted: Fri Mar 07, 2003 9:02 am    Post subject: live setup Reply with quote  Mark this post and the followings unread
live i usually use my laptop, synths, glockespiel, melodica, flute and other FX boxes.
from the laptop, i use fruity loops to play sequenced loops. it's good because i can mute out and apply FX in real time to any track. i can also trigger samples live from fruity loops. i also use a program called BacktoBasics which allows you to use your computer keyboard to trigger samples like you were using a real sampler.
my main synth is a nord lead 2. the best thing about the nord for live stuff, esp. in the ambient realm, is that it has 4 seperate banks that can be played simultanously. so you can have 4 different arps or long sustained notes playing at the same time.
Audio files: 137
PostPosted: Fri Mar 07, 2003 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ahh hah,
Thanks for that explaination. So you really have a lot running on the laptop, not just replays of prerecorded material. I guess with a software based sampler, you can have very long samples too. Also, I didn't realize you had a Nord Lead 2 on stage. (Too busy taking pictures to see anything Very Happy ) I'm a devoted lover of the Nord Modular.
So, when you are running in a live situation, how many tracks are you using at once? Sounds like six or more.
