Buchla 194 Stripboard
Page 2 of 2 [35 Posts]
Goto page: Previous 1, 2
Snaper
PostPosted: Fri Jul 11, 2014 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Nardu wrote:
Snaper wrote:
.... I've used 860 pF instead of 910 (can't find)....
Use 1.5 nF and 2.2 nF in series = 892 pF.
Depending tolerance you may find a pair to reach the 910 pF value .
Works OK with the 860 pF
vladosh
PostPosted: Tue Apr 26, 2016 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
here's a pcb layout for this filter , i dunno if i'll build this at all but i stumbled across this topic and decided to make a layout for it and here it is , it is 80mm width x 75mm high , print should be 300dpi ,here's a link : https://drive.google.com/open?id=0B3v6ZQI_2r7zYUREOGtFOXpBOXc
 Filesize:  697.79 KB
 Viewed:  122 Time(s)
Snaper
PostPosted: Tue Apr 26, 2016 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Vladosh, awesome looking board.
Actually, I've just removed my own 194 from my system. I don't have enough room for new and exciting modules, like my double "Buchlaudino", an Euroduino adaptation Very Happy
vladosh
PostPosted: Tue Apr 26, 2016 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
i will prolly never build this filter unless it becomes part of someone else's system i build .. i got a big panel of 15 modules or so to finish for myself and this is no part of it
vladosh
PostPosted: Tue Apr 26, 2016 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
this pcb takes lot less space if you look it on a very tiny cellphone
LFLab
PostPosted: Tue Apr 26, 2016 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I layed out a board for this as well, and also built a module out of it, but yeah, not enough feature density. Meaning to redo this with VCA's after each band or so to give it a bit more versatility.
Snaper
PostPosted: Tue Apr 26, 2016 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
The vca is a very good idea actually..
vladosh
PostPosted: Wed Apr 27, 2016 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
you can use Haible's filter scanner to sweep thru the 4 channels
 Filesize:  13.85 KB
 Viewed:  107 Time(s)
LFLab
PostPosted: Wed Apr 27, 2016 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
An interesting idea!
vladosh
PostPosted: Fri May 20, 2016 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
here's an attempt for that Jurgen's scanner , i have no way to proto - this ,and test things so i just layout the board with two variations for output , one is with TL071 and is ,or can be identical to the output of the big interpolating scanner from Jurgen , the other option using TL074 which i kind of hope might work is simpler without offset trimpot and is borrowed from a version of Moog VCF ,all this is untested , the matched pairs are BCM
 Filesize:  1.11 MB
 Viewed:  121 Time(s)
 Filesize:  406.37 KB
 Viewed:  103 Time(s)
