Schematics Vault
Page 10 of 11 [251 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11 Next
vladosh
PostPosted: Sun May 19, 2013 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Studio Monitor filter design by A. Grigorova [ Радио, телевизия, електроника - 10 . 1974 ]
 Filesize:  769.65 KB
 Viewed:  352 Time(s)
 Filesize:  573.1 KB
 Viewed:  504 Time(s)
Audio files: 566
PostPosted: Mon May 20, 2013 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
ah, you made it to page 10, congratz! party!
and thanks!, this vault has come in handy a couple of times.
vladosh
PostPosted: Mon May 20, 2013 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Generator za pravoagolno i impulsno naprazhnenie ,Square wave Tube based Generator design by M.Nikolov [Радио, телевизия, електроника 03 - 1968 ]
 Filesize:  652.93 KB
 Viewed:  333 Time(s)
 Filesize:  288.34 KB
 Viewed:  365 Time(s)
vladosh
PostPosted: Tue May 21, 2013 12:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Лесли Симулатор featured in March 1978 edition of Радио ,Телевизија ,Електроника design by D.Avramov
 Filesize:  459.83 KB
 Viewed:  370 Time(s)
 Filesize:  527.33 KB
 Viewed:  376 Time(s)
vladosh
PostPosted: Wed May 22, 2013 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
LFO with variable phase by H. Kribel
 Filesize:  317.6 KB
 Viewed:  604 Time(s)
 Filesize:  190.09 KB
 Viewed:  745 Time(s)
 Filesize:  365.5 KB
 Viewed:  481 Time(s)
 Filesize:  523.49 KB
 Viewed:  505 Time(s)
PostPosted: Wed May 22, 2013 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
What is "Лесли Симулатор" ?
-minus-
PostPosted: Wed May 22, 2013 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Transmitter from Sputnik 1 Cool
 Filesize:  72.18 KB
 Viewed:  551 Time(s)
vladosh
PostPosted: Wed May 22, 2013 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
it's my fault in making post in hurry ,it's a phaser ,the exact effect and what it does i have not tried it to share experience
pq
PostPosted: Thu Aug 22, 2013 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
"Leslie simulator", written in Cyrillic. Might try that, seems interesting.
vladosh
PostPosted: Sun Sep 01, 2013 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
ETI VCF design by Trevor Marshall ,more info on the ETI Synthesizer on the link :[url] http://www.trevormarshall.com/eti.htm [/url] the whole documentation on the ETI International Synthesizers you can download here : http://www.eti4600synthesiser.org.uk
 Filesize:  1.26 MB
 Viewed:  794 Time(s)
 Filesize:  3.75 MB
 Viewed:  747 Time(s)
vladosh
PostPosted: Sun Sep 01, 2013 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
VC Pan from Ogee Synthesizer by Scott Bernardi , more desings from this synthesizer on the following link :
http://www.bernacomp.com/elec/ogee_specs.html
 Filesize:  10.04 KB
 Viewed:  808 Time(s)
vladosh
PostPosted: Sun Sep 01, 2013 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Low Frequency Oscillator by Scott Bernardi from the OGEE Synthesizer ,more on the following link : http://www.bernacomp.com/elec/ogee_specs.html
Features
Selectable Triangle or Sine outputs (+/- 5v with Level control)
Pulse output (0-5v) with PWM control and LED's indicating duty cycle
Frequency control adjusts frequency exponentially from about 0.1hz to 100 hz
 Filesize:  10.36 KB
 Viewed:  743 Time(s)
vladosh
PostPosted: Sun Sep 01, 2013 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Multiplexor by Scott Bernardi more on his OGEE Synthesizer on the link : http://www.bernacomp.com/elec/ogee_specs.html
Features
Switches output between four different inputs
Built in clock, or manual step or external trigger
 Filesize:  12.26 KB
 Viewed:  730 Time(s)
vladosh
PostPosted: Thu Sep 05, 2013 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Voltage Controlled Electro-Optical Mixer design by Grant Richter ,from the description on his site :
A simple and inexpensive device is described which allows selecting and mixing audio channels by control voltage. The circuit takes advantage of the low self-noise of analog photocouplers. The slow response time of the phosphour is used to integrate the pulse width modulated LED drive. Channel crossfading is accomplished by adding a "dither" signal to the comparator string, producing apparent linear crossfades between audio channels.
 Filesize:  32.35 KB
 Viewed:  29367 Time(s)
 Filesize:  186 KB
 Viewed:  719 Time(s)
vladosh
PostPosted: Mon Sep 09, 2013 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Simmons SDS - 3 ,schematic redrawn by xpmtl as posted in the following thread : http://electro-music.com/forum/topic-16985-250.html visit xpmtl's page for a SMT pcb layout http://xpmtl.net/sdiy/projects/simmons-sds-3-voice/
 Filesize:  101.79 KB
 Viewed:  781 Time(s)
vladosh
PostPosted: Mon Sep 09, 2013 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Pollard Syndrum by Joe Pollard and Mark Barton ,schematic and short description provided on http://clacktronics.co.uk/drumlab/pollard-syndrum
 Filesize:  192.47 KB
 Viewed:  1036 Time(s)
vladosh
PostPosted: Wed Sep 11, 2013 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Drum Tone Oscillators by PAiA as presented in an article in the June 1993 issue of Electronics Now , full description at PAiA website : http://www.paia.com/ProdArticles/syndrum.htm
 Filesize:  34.96 KB
 Viewed:  748 Time(s)
vladosh
PostPosted: Mon Sep 23, 2013 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Fleuril - VCF as part of the White Rose modular synth , schematic shared on the following blog http://thermidor.altervista.org/fleuril-vcf/ , from the description there :
The filter developed for this synthesizer is a Sallen-Key, whose control voltage is achieved with diode-ladder.
The idea of how to develop this type of circuit l' I got it from a project by Osamu Hoshuyama, which is available here : http://www5b.biglobe.ne.jp/~houshu/synth/Vcf0111.gif
 Filesize:  89.28 KB
 Viewed:  769 Time(s)
vladosh
PostPosted: Mon Sep 23, 2013 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
External input and VC Clipping Limiter by Stefano Maurri : http://mwpc1.det.unifi.it/~maurri/synth.html
 Filesize:  154.41 KB
 Viewed:  1032 Time(s)
vladosh
PostPosted: Wed Feb 05, 2014 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Dual ADSR ,by Adriano Lazzari & Riccardo Monti ,from September 1978 issue of Italian magazine - Onda Quadra ,full article contains pcb layout and BOM
 Filesize:  550.06 KB
 Viewed:  646 Time(s)
vladosh
PostPosted: Wed Feb 05, 2014 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
VCF by A.Lazzari and Riccardo Monti featured October 1978 issue of Onda Quadra ,more details on the construction in the full article
 Filesize:  452.34 KB
 Viewed:  654 Time(s)
 Filesize:  1.25 MB
 Viewed:  636 Time(s)
vladosh
PostPosted: Fri Feb 07, 2014 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
VCO by Stephen Winter ,the whole pdf document in German containing double sided PCB layouts can be found here : http://www.uni-muenster.de/imperia/md/content/fachbereich_physik/technik_didaktik/entwicklung_bau_synthesizer.pdf
 Filesize:  908.57 KB
 Viewed:  627 Time(s)
 Filesize:  375.91 KB
 Viewed:  795 Time(s)
vladosh
PostPosted: Sat Feb 08, 2014 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
The E&MM Spectrum Synthesizer design by Chris Jordan of E&MM ,from the description :
- The Spectrum is a monophonic two oscillator switch-linked synthesiser featuring advanced specification, constructional simplicity and low cost. Modulation, timbre control, and interface facilities not found on any
comparable synthesiser make it extremely powerful and versatile for keyboard playing, sound effects and
many other home, stage, or studio applications. , the Special Edition issue with pcb layouts and tips on building the Spectrum http://www.bigbluewave.co.uk/images/spectrum-notes-04.pdf
 Filesize:  42.09 KB
 Viewed:  606 Time(s)
 Filesize:  68.86 KB
 Viewed:  546 Time(s)
 Filesize:  102.74 KB
 Viewed:  780 Time(s)
vladosh
PostPosted: Fri Feb 14, 2014 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
FET VCA by Mike Irwin ,published in EDN - September 05, 2002 ,details on this circuit here : http://www.edn.com/design/analog/4339537/Op-amp-linearizes-response-of-FET-VCA
 Filesize:  257.78 KB
 Viewed:  601 Time(s)
 Filesize:  2.43 MB
 Viewed:  552 Time(s)
Nardu
PostPosted: Fri Feb 14, 2014 6:12 am    Post subject: Phase modulator for "Leslie" effect Reply with quote  Mark this post and the followings unread
Here, the OCR scanned document for Phase modulator for "Leslie" effect :
- http://www.scribd.com/doc/207120047/Leslie-effect
http://nardusynth.blogspot.ro/
