Any simple bass drum schematic? or snare?
Page 1 of 2 [36 Posts]
wahoah
PostPosted: Wed Jan 30, 2013 5:53 pm    Post subject: Any simple bass drum schematic? or snare? Reply with quote  Mark this post and the followings unread
Hi!
Ive been serching for a simple bass drum schematic and havent find anything, a snare could be great too or a hi hat
anyone have one?
-minus-
PostPosted: Wed Jan 30, 2013 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi. I'd suggest the Korg Monotribe drums. They are transistor based. I have recently built the 3 voices on pieces of stripboard. They are quite straight forward and will run on 9V. You'll need a noise source too. I made a simple two transistor white noise generator which works fine. Breadboard the circuits first as I found by fiddling with the values I got a better result for what I wanted. I also added a open hat sound. Here's the schematic...
monotribe_schematic.pdf
 Filename:  monotribe_schematic.pdf
 Filesize:  56.41 KB
 Downloaded:  2092 Time(s)
wahoah
PostPosted: Wed Jan 30, 2013 6:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
what i should do with the IC on the first part of the schematic?
im guessing that mi input (the part that says BD) will be like a Control voltage input?
And could i use a 2n2222 transistor?
 Filesize:  32 KB
 Viewed:  29667 Time(s)
-minus-
PostPosted: Wed Jan 30, 2013 8:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
What I did with the input is this. I removed that section you circled on the schematic and replace it with a diode, 100K resistor to ground, and 0.1uF cap. This means I can trigger the drum to fire using a gate signal of any length. I am using these drums in my logic synth/Lunetta so it is handy to be able to trigger the drum from a logic signal..
I used 2N3904's in mine but a 2N222 should work as well. Also, I added the output transistor section to the right of the schematic from Korg. I left off the PORT section and just added everything on the right of that. This gave the kick drum heaps more BOOOOM. Oh, and I used a 1K pot going to Ground where Korg have BD DECAY labelled. This gives the kick drum adjustable decay to a point of self oscillation.
 Filesize:  86.46 KB
 Viewed:  483 Time(s)
-minus-
PostPosted: Wed Jan 30, 2013 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I should have done this before. Mine looks like this:
 Filesize:  85.54 KB
 Viewed:  1017 Time(s)
Tony Deff
PostPosted: Sun Feb 03, 2013 10:34 am    Post subject: Re: Any simple bass drum schematic? or snare? Reply with quote  Mark this post and the followings unread
wahoah wrote:
Hi!
I've been searching for a simple bass drum schematic and haven't found anything; a snare could be great too, or a hi hat.
Anyone have one?
Aloha, Wahoah,
I built a very passable set of 8, way-back in the previous millenium, from a design published in Practical Electronics here in the 51st State.
I may still have it, but don't fancy re-drawing the schematics from the original stone-tablet carvings.
Whilst quickly looking to see if was archived on-line, I came across this set of Carillon (The bells! The bells!)
Everyday Practical Electronics 2008 PDF (scroll down to page 35).
Hells bells.
-minus-
PostPosted: Mon Feb 04, 2013 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thers some reasonabell Laughing chimes to be had from Ken Stone's Chime Simulator...
http://www.cgs.synth.net/modules/cgs19_chime.html
I built this and the bells are quite convincing although not easily retuned.
Or for a kick sound you could try Eric Archers Mini Space Rockers...
http://ericarcher.net/devices/mini-space-rockers/
I built this too. There are three caps you can experiment with to get a variety of tones. This is a simple circuit and easy to breadboard and play around with. There are some sound files on Eric's site with various cap sizes and the sounds they create. I couldn't make my mind up on the caps so I used three twelve position rotary switches... giving me... 12 X 12 X 12 variations Confused
PostPosted: Mon Feb 04, 2013 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't forget Thomas Henry's MPS. It is a lot of kit for 1 drum, but it definitely allows for everything. 3partials/RM/Noise filter.
It's a very small board too, laid out by yours truly! Cool Embarassed
wahoah
PostPosted: Thu Feb 07, 2013 9:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
ive just breadboarded the Bass Drum from the monotribe korg, i like it but i need a little more bass and deeeper sound
any recomendations?
PostPosted: Thu Feb 07, 2013 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/phpbb-files/kick_and_snare_652.mp3
That's from 808 and snare stripboards from here:
http://electro-music.com/forum/topic-37646.html&postorder=asc
http://electro-music.com/forum/viewtopic.php?highlight=808+snare+stripboard&t=45134
-minus-
PostPosted: Thu Feb 07, 2013 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
any recomendations?
Try a few different transistors, even of the same type. I replaced the quite a bit until I found one I liked. Have you used a decay pot? That will give it more boom. The other option is to try a more complex circuit like the 808. You'll need a bipolar power supply to run it though.
wahoah
PostPosted: Thu Feb 14, 2013 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
-minus- wrote:
any recomendations?
im not 100% shure of the location of that decay pot
i have a drawing right here, its right where i placed?
 Filesize:  53.49 KB
 Viewed:  405 Time(s)
-minus-
PostPosted: Thu Feb 14, 2013 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that is correct. Is it having no effect for you?
KRS1972
PostPosted: Thu Feb 28, 2013 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello !
have you seen this topic ?
http://electro-music.com/forum/topic-28447.html
I build this one, and it is a great sounding bass drum.
grt,
Chris
EATyourGuitar
PostPosted: Wed Mar 06, 2013 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
what you want is a simple sine VCO and a monostable source like a 555 RC lowpass'd to get a decay envelope. your envelope controls the pitch of the sine wave. you can skip the VCA if you just high pass the bass drum sound right around 100hz. that should give you a nice fade out from a single envelope.
Biyi
PostPosted: Sun Sep 29, 2013 11:10 am    Post subject: monotribe bassdrum stripboard
Subject description: monotribe bassdrum stripboard
HI everybody,I build this one,its a good drum sound for lunneta...for some strange reason, on the breadboard the decay bass work, but on stripboard not .... might be wrong??'s have reviewed and operates everything, but the decay of bassdum seems not working.Hey-minus-good job, I am fascinated by your stripboard designed.can somebody helps? Thankyou world!!
monotribe bassdrum.pdf
Stripboard monotribe bassdrum..this is only bass section without amp circuit.
 Filename:  monotribe bassdrum.pdf
 Filesize:  39.18 KB
 Downloaded:  830 Time(s)
PostPosted: Sun Sep 29, 2013 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Several questions come to mind....
You're using a diode on the input rather than an inverter? I assume they're using an inverter because they use a negative going trigger pulse?
What is the 100K to ground immediately after the input diode?
In the original schematic, four of those five caps are 105, not 104.
I'm having difficulty following what goes where with the 470K resistor and three of those caps, but I think it looks like your stripboard matches the schematic other than the values.
Biyi
PostPosted: Mon Sep 30, 2013 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Elmegil Thanks for answering! ...-Minus several things described above of the page, the replaced the inverter by a diode, one 100k resistor and 0.1 uf cap.
I'm not sure which function has 100k resistor, but it works very well .. guess it will be a discharge resistor, because without it does not work.
The circuit works perfectly as I said-minus-and I've been tested.
The caps = 104 = 100nf 0.1uf are correct at the basdrum., That for me it worked very well with the decay but on the breadboard, and does not work the decay in the stripboard ..
I do not know why? if it is the same circuit that apart snaredrum caps are 0.018 uf = 18nf = 183
It's strange because the snaredrum stripboard, works perfectly with the decay pot.
Thanks.
PostPosted: Mon Sep 30, 2013 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried a different pot?
Sorry if this was already discussed above too.
Biyi
PostPosted: Mon Sep 30, 2013 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
yes elmegil,i tried pot,resistors......iI think I'll start a new stripboard for bassdrum .. but it is strange that in bredboard work the decay and the stripboard not ... Crying or Very sad I will continue to see ,what happens!
richardc64
Audio files: 26
PostPosted: Mon Sep 30, 2013 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
any recomendations?
You can lower the pitch by increasing the caps: Try putting 0.01 or 0.05uf in parallel with C74,76,77. You can vary the pitch to a limited extent by varying R73 or R74 or R79. (Too much or too little will stop oscillation.)
Biyi
PostPosted: Tue Oct 01, 2013 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello everyone ... the stripboard is correct! My mistake was to build it, I'm wrong mistaking one of the resistors 15k by 150k (confused the color code of resistors of 1%) that will serve me to always check with the voltmeter! elmegil thanks for your interest.
Richardc64 Thanks for these tips, I now see that you can create sounds as conga, toms etc, just replacing the caps and resistors.
Any idea to create a sequencer to trigger these modules? perhaps a 4017?
Thanks world!
Biyi
PostPosted: Tue Oct 01, 2013 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
and here, the stripboard of snaredrum without noise.. soon the rest of the monotribe drum modules..i hope...
monotribe snaredrum.pdf
 Filename:  monotribe snaredrum.pdf
 Filesize:  39.17 KB
 Downloaded:  784 Time(s)
Biyi
PostPosted: Fri Oct 04, 2013 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
here is the first test with basdrum and snaredrum with noise .. looks good ... the next will be the hihat ....
https://www.facebook.com/photo.php?v=10151753905839398&set=vb.742704397&type=2&theater
new voodoo
PostPosted: Thu Nov 14, 2013 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hahahah.
I did the EXACT same thing. Twice. Then put it in a box and forgot about it..until now.
Just took it out--and it still wrks!!
crazy. My mistake was leaving in the momentary switch triggers. I mean, am I ever gonna sit around pushing a button every 1/4 bar or whatever for a song or smething? Probably not.
Anyways, i think ill ebay it. If anyone here is interested, Id be glad to give it away for shipping cost.
