Poll of the month
Page 1 of 1 [4 Posts]
Would you have chosen differently if you:
Found the option highly appropriate?
12%
 12%  [ 1 ]
Voted again in a different poll?
0%
 0%  [ 0 ]
Didn't vote, but thought about it?
25%
 25%  [ 2 ]
Voted with your feet?
0%
 0%  [ 0 ]
Tried to avoid the leading question?
0%
 0%  [ 0 ]
Found it very likely?
12%
 12%  [ 1 ]
Were very satisfied?
0%
 0%  [ 0 ]
Found it OK, but not quite...
12%
 12%  [ 1 ]
Don't know? (How is that going to help?)
0%
 0%  [ 0 ]
Couldn't care less (except if you didn't vote at all)
0%
 0%  [ 0 ]
Try again next month
37%
 37%  [ 3 ]
Total Votes : 8
Audio files: 495
PostPosted: Tue Feb 19, 2013 7:18 am    Post subject: Poll of the month
Subject description: Have your say
Please select as appropriate per your opinion if this applies to you when your ticked option is deemed valid, as to whether the resulting statistics of this poll will result in a follow-up poll for use in determining whether the question in question should be phrased in such a way that is makes you opinion count significantly when the question will be formed from the sum differential result of the accumulated counted opinions totalled after having been counted.
PostPosted: Tue Feb 19, 2013 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would have chosen differently if I had been offered a cookie.
-minus-
PostPosted: Tue Feb 19, 2013 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
All of the above.
Audio files: 495
PostPosted: Wed Feb 20, 2013 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for voting! Smile
The winner can not be announced because it is an anonymous poll. Please vote again soon.
