Closed
Page 1 of 1 [19 Posts]
sonicwarrior
PostPosted: Sun Feb 10, 2013 3:41 pm    Post subject: Closed Reply with quote  Mark this post and the followings unread
Closed
sonicwarrior
PostPosted: Mon Feb 11, 2013 6:24 am    Post subject: Re: FS (EU): PCB's and front panels
Subject description: MFOS ADSR, MFOS AR, CGSRR, CGS DUSG, Dual DBX VCA, Melcor 1731
sonicwarrior wrote:
4 x MFOS ADSR kit + Bridechamber front
Btw.: If anyone is interested in the front panels only I'm willing to sell them separately but I won't sell the PCB kits separately.
The breadboard stuff is really simple (LED driver is a transistor and some resistors, the inverter is mainly a single op amp and some resistors). And instead of the LED you can mount a speed switch there (the hole is big enough for standard switches).
I build one of these ADSRs and found the inverted output pretty useful but I'm more into Buchla/Serge Slew Limiter multitool modules nowadays than standard ADSRs + I already have 3 ADRSs in my 5U system.
roglok
PostPosted: Tue Feb 12, 2013 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
someone grab the MFOS Dual AR - it's a great module!
sonicwarrior
PostPosted: Tue Feb 12, 2013 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. The ADSRs are great, too, but I already have too many.
It seems like no one is building MOTM modules anymore. Sad
PostPosted: Tue Feb 12, 2013 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm doing MOTM format, but then again I don't need any of these modules, I'm really in need of sequencers and other sources of control voltage....
sonicwarrior
PostPosted: Sat Feb 16, 2013 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Added a dual mic pre set and two Lundahl LL1521.
Alfredo
PostPosted: Sat Feb 16, 2013 7:13 am    Post subject: MFOS AR Reply with quote  Mark this post and the followings unread
Hello, I will take the MFOS AR.
Thanks.
sonicwarrior
PostPosted: Sat Feb 16, 2013 7:26 am    Post subject: Re: MFOS AR Reply with quote  Mark this post and the followings unread
Then please send an email to the address I PMed you.
Alfredo
PostPosted: Mon Feb 18, 2013 4:57 am    Post subject: I PMed you Reply with quote  Mark this post and the followings unread
Hello, I already PMed you back.
sonicwarrior
PostPosted: Wed Feb 20, 2013 12:56 pm    Post subject: Re: I PMed you Reply with quote  Mark this post and the followings unread
Yes, but I wanted an email not a PM.
Anyway the MFOS AR has gone in the meantime.
Alfredo
PostPosted: Wed Feb 20, 2013 4:22 pm    Post subject: Not good man Reply with quote  Mark this post and the followings unread
I sent you an email too same day, that´s no good man no no
sonicwarrior
PostPosted: Thu Feb 21, 2013 2:21 pm    Post subject: Re: Not good man Reply with quote  Mark this post and the followings unread
I sent you my email address on the 12th and got your email at the 17th in the meantime (5 days!) someone else emailed me. Prior to your email I only got PMs from you and I don't do business via PMs.
Alfredo
PostPosted: Thu Feb 21, 2013 3:05 pm    Post subject: Not good man Reply with quote  Mark this post and the followings unread
Negative feedback for you.
 Filesize:  19.89 KB
 Viewed:  9895 Time(s)
PostPosted: Thu Feb 21, 2013 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
@sonicwarrior ... I don't see an email only response request in your starting post here, maybe it would be a good idea to add it - I guess you said so in a later PM, still it might help to get less misunderstanding?
@Alfredo .. I'm sorry to see you getting so disappointed about the failed deal, and I of course do not know the details of the affair, but from what is visible here in the thread .. could it be that you are overreacting a bit?
Alfredo
PostPosted: Fri Feb 22, 2013 8:15 am    Post subject: Thanks Blue Angel Reply with quote  Mark this post and the followings unread
Thanks Blue Angel for your attention, no problem I preffer to finish.
Sorry sonicwarrior.
sonicwarrior
PostPosted: Fri Feb 22, 2013 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
For me it's normal to not send sensitive informations via PM. I never had a problem with anyone writing an email until now with Alfredo and I sold much stuff over the years. I clearly said in my PM from the 12th that he should send me an email ([shipping costs to Spain] 'If you are still interested please write an email to ...'). On the 16th someone else contacted me and was able to respond directly per email so he got the MFOS AR PCB. Alfredo finally was able to write an email on the 17th but that was too late then. I only reserve stuff when I got a notification via email that payment is on the way. I do that because I got lots of PMs from people who have not been serious or changed their mind but everytime I got an email I got a deal. I guess people take emails more serious than PMs.
PostPosted: Fri Feb 22, 2013 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I understand and would do the same. Not that such matters, as it is up to you how to handle selling your things.
And just to be sure, I am not blaming anyone, just tried some suggestions. Anyway, thank you for your explanation.
sonicwarrior
PostPosted: Fri Mar 01, 2013 12:11 pm    Post subject: Re: FS (EU): PCB's and front panels
Subject description: MFOS ADSR, MFOS AR, Dual DBX VCA, Melcor 1731, Dual MicPre, Lundahl
sonicwarrior wrote:
4 x MFOS ADSR kit + Bridechamber front, 50 € each
This is the old Bridechamber front panel in MOTM format with LED + inverted out
I'm willing to sell the Bridechamber fronts separately for 25 € each if anyone is interested.
modulardoom
PostPosted: Wed Mar 13, 2013 6:31 pm    Post subject: MFOS ADSR Reply with quote  Mark this post and the followings unread
I am interested in one MFOS ADSR Kit + front panel
send me a PM if they are available.
thanks a lot
