  Twyndyllyngs Live Chez Mosc
Noise! Noise! Noise!
Page 1 of 1 [6 Posts]
autowitch
PostPosted: Mon Mar 18, 2013 1:49 pm    Post subject: Noise! Noise! Noise! Reply with quote  Mark this post and the followings unread
Just some fun with melody generators, shift registers, ring mod and pitch tracking. Sort of taking everything and throwing it together to see if something interesting happens. I probably should have cut the length down a bit...
https://soundcloud.com/autowitch/sausage-party (with too much reverb)
https://vimeo.com/62040867 (video - not enough reverb Smile )
Sausage Party from the autowitch on Vimeo.
Edit: I was trying for garbled and out of control.
Draal
PostPosted: Wed Mar 20, 2013 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Super build there Cool .
That's alien abduction music in my book!
Zontar Prevails!
analog_backlash
Audio files: 21
PostPosted: Tue Mar 26, 2013 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Autowitch.
I've only just got round to listening/watching these posts (I had to be in a patient mood because, as you say, they are quite long!). Really like some of the sounds that you're getting. I'm building a lunetta at the moment (I will post very soon - I keep saying that).
Ditto.
Just wondered which circuits you've used for pitch tracking (a 4046-based circuit?) and the shift registers. I have lots of schematics in my collection, but I'm not sure which ones to try.
Keep up the good work,
Gary
autowitch
PostPosted: Fri Mar 29, 2013 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Gary,
I'm looking forward to seeing what you are working on!
I used this thread for the pitch tracker. I used the 4049/4046 version (more specifically the breadboarded one in the middle of the thread).
http://electro-music.com/forum/topic-51275.html
The pitch tracker can vary pretty wildly depending on the manufacturer you use for the chips. I don't quite get the laser bloops that some people do, but I do get a nice texture of gurgles. I'm planning on building another one using a different source for the 4046 and seeing what happens.
I suspect that tweaking the caps will lead to some pretty dramatic changes in the behavior. (You must build a pitch tracker; I can't recommend it enough).
For the shift registers, I started with this:
http://electro-music.com/emsynth/PseudoRandom.html
I only have one bit hooked up. I wasn't sure how to seed the bits going into the shift register, so I added a push button going from hot to one of the legs of the XOR input. That effectively gives me a bit toggle that I can use to seed the shift register as it starts or to tweak it when it runs.
I think using an XNOR instead of an XOR may handle this problem on its own; but I've decided that I like the manual tweaking.
I made two outputs for the "random" bits. One is just like it's seen in the emSynth schematic. The other ANDs the bit with the clock; that would give a pulse output. This could be fun if combined with the drum circuits found here: http://electro-music.com/forum/topic-52786.html
The eventual plan is to create four of these using the various XOR connections in the emSynth version. That should provide a source for 4 bit random numbers that could be used for all sorts of things.
-aw
PostPosted: Sat Mar 30, 2013 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
If you are interested, there was some discussion of a few other 4-bit pseudo-random generators here: http://electro-music.com/forum/topic-52066.html
James.
Dogenigt
PostPosted: Mon Apr 01, 2013 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi aw, try unplugging your ground connection to your 4046, I did that with my CD4046BE and suddenly the lazer sweeps came on! very strange...!
www.dogenigt.com
Everything should be made as simple as possible, but no simpler. - Albert Einstein
