G2 and expression pedal.
Psoas
PostPosted: Fri Mar 22, 2013 3:11 pm    Post subject: G2 and expression pedal. Reply with quote  Mark this post and the followings unread
Hy
Does that input connector (ctrl pedal) allow to connect an expression pedal to change main volume while playing ?
If yes, how to set up ? in the editor ? and how ?
I tried with some modules and it works, but don't find how and with which module to connect for main volume.
Thks
PostPosted: Fri Mar 22, 2013 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Psoas
The control pedal maps to morph knob 6 (when it is not set to "knob" node), so you can use morph 6 to control whatever you want in your patch.
oh, and no double posting please - I removed the other one.
Psoas
PostPosted: Sat Mar 23, 2013 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hy...
Thank you for your answer and sorry for double post.
In the user manual i read something about what you say.
So i tried to do so, but I did'nt found a connector to link my pedal on the output modul in the editor. I must say i'm not familiar with modular and in fact I'm more a "preset user with minor modifications".
In a single patch in the editor can you link this function so that i can understand and send me a screenshot of how you did it ?
would be great....
Tks
