Pitch stick broken
Page 1 of 1 [6 Posts]
brm
PostPosted: Tue Apr 02, 2013 12:37 pm    Post subject: Pitch stick broken
Subject description: Yes, an other pitch stick is broken
Hi there,
I am very happy with G2, but now the PitchStick™ goes crazy on me.
I already tried a couple of times to get my broken PitchStick™ fixed. I tried 3 local synth repair shops ( Berlin ) without any luck. The last one told me i had to ask or order the part at Clavia directly because he also didn't had any clue how to get the spare parts.
He said the "torsion strip" is worn out and has to be replaced.
I tried clavia's email form but nobody seems to respond.
Is there any way to get to Clavia and order the PitchStick™ ? Or is there an other way to replace this "torsion strip" ?
Thank you very much!
varice
G2 patch files: 53
PostPosted: Tue Apr 02, 2013 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome to the electro-music.com forum brm Exclamation
Clavia wrote:
In need of spare parts or maintenance?
Warranty and maintenance is handled by our distributors, and in some cases by special service centers. Please consult you point of purchase for detailed information.
People usually have better results by contacting their local Clavia distributors:
http://www.nordkeyboards.com/main.asp?tm=Distributors&dm=All_distributors
Your local synth repair shops should have known this Exclamation
Good luck with your repair.
varice
Fozzie
G2 patch files: 49
PostPosted: Wed Apr 03, 2013 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, I just did the same repair myself, getting the part from the Dutch supplier (music service). Isn't cheap (~100 euros incl VAT) but worth it - the clavia pitch stick is too good to miss. Repair isn't difficult. If you don't want to solder on a circuit board, you can connect wires mid-way as I did. Works perfectly. Only thing is the color code of the wires changed, so you have to be careful how to connect...
brm
PostPosted: Wed Apr 03, 2013 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanx everybody!
After three emails in the last 3 months to Clavia the one yesterday finally came through. They where very nice and are trying to fix this with a local distributor. I hope a PitchStick will be sended to me so i can solder myself.
@ varice: first i contacted the local distributor from the site, he put me through to a synth repair shop. In the end the Shop put me back to Clavia, so there is the loop Smile
Keep u Updated on this little story
steevyhead
PostPosted: Sat Apr 06, 2013 9:23 pm    Post subject: same problem here Reply with quote  Mark this post and the followings unread
unfortunately my pitch stick has gone as well... it works sometimes, and when it does it stutters which makes me think that its a short somewhere. If thats the case do i not need to replace the pitch stick itself, or do I? I haven't opened up the unit itself as I am afraid to haha. It is my baby, I JUST got it.
steve
Nodular
G2 patch files: 7
PostPosted: Fri May 09, 2014 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I replaced the stick of my unfortunate G2X unit. I wrote Clavia support and they have been really kind and sent me 2 sticks at a very reasonable price. I have a solder/desolder machine (desolder pistol is a great invention) and I managed to do the job quite easily (I'm not particularly good at soldering). Now the bad news. Firstly it seemed to work but in a few weeks the erratic behavior of the pitch stick was back again and it's still there. As the unit presents other weirdnesses (on buttons) I started thinking the pitch itself could not be the culprit. Crying or Very sad
