Assigning Sustain Pedal
dartanjal
PostPosted: Thu Apr 11, 2013 7:47 am    Post subject: Assigning Sustain Pedal Reply with quote  Mark this post and the followings unread
Hello everyone,
I am trying to assign a sustain pedal (through the sustain pedal input) to 'push' a button on a module. (where I need to hold down the button for a certain duration of time and then let it go)
This seems like an obvious assign problem. But I cannot get it to work.
Any idea of where I can do this? I've tried assigning CC's (right click on the button) but that doesn't seem do anything.
Any help would be greatly appreciated!
Jim
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Apr 11, 2013 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
The "device" module (from the In/Out-tab) offers control outputs of all G2 performance controllers, among them a logic gate for the sustain pedal. I'd use that.
dartanjal
PostPosted: Thu Apr 11, 2013 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Tim! I will look into this tonight.
It's funny that you responded, because I'm actually using your PolyGranuSyn_Y and PolyGranuSyn_Z patches as a starting point for my performance setup!
I am processing guitar and wanted to use the sustain pedal to trigger the 'Capture' (audio) button.
Hopefully I can negotiate the DSP balance to add in the devices module. Wink
