SN Voice final problem
PostPosted: Sun Apr 21, 2013 9:13 pm    Post subject: SN Voice final problem
Subject description: noise filter???
The Noise Filter doesn't appear to have any effect at all.
I've checked it and it appears to be wired correctly. Since the pot is just a rheostat to ground and the cap is also just going to ground there's not a lot to go wrong. I've verified the pot is a 1M and the cap is a 470pF....
Any ideas?
Some more description: if I sweep the init value for the noise, the low end is very intermittent sound, as I sweep higher it sounds like the old Defender video game shooting noise (go figure), and when I get past about 3-O'Clock on the pot the high end is pretty much just occasional ticks.
I figured I should test the filter with the init set somewhere in that middle section where it's "very" noisy, so that's where I set it. When I sweep the pot for the filter I hear absolutely no difference in the sound.....
PostPosted: Sun Apr 21, 2013 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Neva mind.... I think I must have had the cutoff set all the way clockwise before, I have now put it all the way CCW and I can definitely hear a difference when Init is high enough.....
