G2: midi internal / external sync problem after patch load
18knobs
PostPosted: Mon Apr 29, 2013 12:58 pm    Post subject: G2: midi internal / external sync problem after patch load Reply with quote  Mark this post and the followings unread
I am hoping to find an answer to the following, which has been bothering me for a while and I don't find any solution elsewhere:
My G2 is the midi master for further gear connected to the Midi out. When I load a new patch into the G2, the midi out sync keeps ticking correctly, but the internal midi sync of the G2 looses sync. So the tempo stays the same, but step of the G2 patch one isn't where step one should be.
This happens no matter if I connect the Rst in of the sequencer module to midi syn or clock active out of the clock generator module.
Is there a trick to solve this?
thank you in advance
18knobs
Electromagnetic Wave
G2 patch files: 30
PostPosted: Tue Apr 30, 2013 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi 18knobs,
When you load a new patch, the sequencer restart to the first step. Same if the sequencer don't have a wire into the Rst input. Do you know the new patch to load ? You can put 2 patch into 1 slot and pass from one to other one with variation
18knobs
PostPosted: Tue Apr 30, 2013 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
The internal sequencer will start from the first step, yes. But this does not match step one of the midi clock sync that is sent via Midi out to external midi gear.
And I want to play more than just 4 patches after another, so I must reload. i also want to load new performances. So this doen't help me Sad
