why cant i open any patch?
Page 1 of 1 [9 Posts]
Muzik 4 Machines
PostPosted: Sun May 05, 2013 1:33 pm    Post subject: why cant i open any patch? Reply with quote  Mark this post and the followings unread
i get the same error on EVERY one of my patches
net.sf.nmedit.jpatch.clavia.nordmodular.parser.ParseException: error@259:0: expected '/' (<end>), found <EOF>
   at net.sf.nmedit.jpatch.clavia.nordmodular.parser.PParser.emiterror(PParser.java:160)
   at net.sf.nmedit.jpatch.clavia.nordmodular.parser.PParser.emiterror(PParser.java:178)
   at net.sf.nmedit.jpatch.clavia.nordmodular.parser.PParser.sections(PParser.java:275)
   at net.sf.nmedit.jpatch.clavia.nordmodular.parser.PParser.parse(PParser.java:206)
   at net.sf.nmedit.jsynth.clavia.nordmodular.utils.NmUtils.parsePatch(NmUtils.java:453)
   at net.sf.nmedit.jpatch.clavia.nordmodular.NMPatch.createPatchFromFile(NMPatch.java:521)
   at net.sf.nmedit.nordmodular.NmFileService.openPatch(NmFileService.java:80)
   at net.sf.nmedit.nordmodular.NmFileService.open(NmFileService.java:137)
   at net.sf.nmedit.nomad.core.Nomad.openOrSelect(Nomad.java:946)
   at net.sf.nmedit.nomad.core.swing.explorer.FileNode$3.run(FileNode.java:380)
   at net.sf.nmedit.nmutils.swing.WorkIndicator$WrappedRunnable.run(WorkIndicator.java:60)
   at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
   at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:708)
   at java.awt.EventQueue.access$400(EventQueue.java:82)
   at java.awt.EventQueue$2.run(EventQueue.java:669)
   at java.awt.EventQueue$2.run(EventQueue.java:667)
   at java.security.AccessController.doPrivileged(Native Method)
   at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:678)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
[/img]
Audio files: 216
PostPosted: Sun May 05, 2013 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know, could you post one of those patches here so I could see it or try to open it in the Clavia editor?
Muzik 4 Machines
PostPosted: Sun May 05, 2013 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
see attachement
its just a random patch from the folder, but every patch i tried (i tried over 100) gave me the error, be it my own patches, the factory presets, or any patch from clavia site
Noisypad.pch
 Filename:  Noisypad.pch
 Filesize:  2.65 KB
 Downloaded:  196 Time(s)
Audio files: 216
PostPosted: Sun May 05, 2013 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok .. that one is
Version=Nord Modular patch 1.10
Nomad can only handle 3.0x patches ... I read your comment in the other thread too, but unfortunately the Clavia software is the only software able to do the conversion ... however a lot of patches had been converted .. there is an URL in that other thread I think ...
Muzik 4 Machines
PostPosted: Sun May 05, 2013 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
but all my own are 3.03 and still cant be opened Sad
Audio files: 216
Could you post an example of one of those too?
Muzik 4 Machines
PostPosted: Sun May 05, 2013 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'll post some tonight as i'm not home now and those patches of mine are from a network drive at home, so ill post some later, thanks
i'm really pissed at clavia today for being too lame to make a non PPC editor after all this time
Audio files: 216
PostPosted: Sun May 05, 2013 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's getting late here so probably it will be tomorrow before I can check it out then ... heh ... I already thought I sensed some frustration ... will try to help you out though Laughing
Muzik 4 Machines
PostPosted: Sun May 05, 2013 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, im pissed cause i bought a new laptop that costed like 3 months rent, and i cant use the most basic software on it (and i just needed to change a pitch bend range in 1 patch lol)
thanks for your help, and no worry if its tomorrow, i think i will need to just buy a new hardrive for my (i thought) garbage laptop (i guess i will still need it after all if i want a working editor)
