  Twyndyllyngs Live Chez Mosc
 Forum index » Online Music
Yesterday's experimental track
Audio files: 32
PostPosted: Mon May 20, 2013 3:05 pm    Post subject: Yesterday's experimental track
Subject description: Long sequences with long loops
This track is my latest experiment with my DIY modular synthesizer.
My direction has been to work with psuedo-randomness -- that is, music that starts out sounding random but gels over time.
I've also wanted to explore the use of what I call VLLs -- very long loops. These are loops that are long enough that the repetition isn't obvious.
I didn't play this with the intention of posting it however I it is kind of relaxing and thought I'd go ahead and share it. Also, I was chatting on line with Edison Rex and I promised him I'd post this.
If you like micro-tonal music, sample/hold texture, and music that is somewhat spacey, then you may like this track.
PsuedoRandom_Improv_May19_2013.mp3
Experiment in Pseudo-Random texture recorded on May 19, 2013 on Kevin's DIY Modular Synthesizer.
 Filename:  PsuedoRandom_Improv_May19_2013.mp3
 Filesize:  46.2 MB
 Downloaded:  1649 Time(s)
Audio files: 242
PostPosted: Tue May 21, 2013 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is very nice!
Audio files: 32
PostPosted: Thu May 23, 2013 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is very nice!
Thank you!
Here is a little more detail about the track:
As I was developing my "Skip First clock after sync" module my original idea was that I needed a way to keep my (analog) sequencers and clock dividers from "skipping" ahead of the correct clock signal. But I started to ponder other uses and stumbled on the idea that I could mix the outputs of many oscillators to obtain a waveform similar to random slow noise. If the looper's reset signal is used to sync the oscillators, then I would be assured (within the stability of the oscillators) that a sample taken at any given point in the loop would be the same on each repetition. The result is a sequence of voltages the length of the loop (even if the the loop is very long).
Another point of interest is that I used the Yusynth Transistor-Ladder VCF (Minimoog clone) and, at times, used the Yusynth Fixed Filter bank.
I anticipate some future efforts wherein I will quantize the sampled voltages to do 12-TET or other (14-TET) temperaments. This track was unquantized -- thus microtonal.
