MFOS Power supply for TH designs???
acidblue
PostPosted: Fri May 24, 2013 4:31 pm    Post subject: MFOS Power supply for TH designs??? Reply with quote  Mark this post and the followings unread
Is the MFOS dual wal-wart supply good enough to power TH modules??
I noticed Ray's design only uses 2 diodes to rectify the incomming AC signal, is this enough?
http://www.musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&VPW=1270&VPH=502
PostPosted: Fri May 24, 2013 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two possible answers.
1) Thomas' circuits don't require special power supplies Smile Anything that provides +/- 15V will do fine.
2) Ray's supply as shown is for +/- 12V. You can get Thomas' circuits to work at 12V but it will require adjusting various resistors on control voltage input sections, and I don't know of a good resource to just tell you what the changes ought to be.
Another alternative would be to build the WWPS but use 7815 and 7915 and get +/- 15V. For that to work you need a 16VAC Wall Wart though. And yes it does work, I have one that I'm using for a different project...I suppose "work" means it generates the voltages expected, because I haven't yet built enough of the project to put any load on the supply Smile.
Ray's use of two diodes instead of a full bridge is a way to get around not having a center tap, I believe.
acidblue
PostPosted: Fri May 24, 2013 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
AHA! I was suspicious of this.
Thanks for the reply.
