jmcecil
Joined: May 11, 2013 Posts: 20 Location: Prattville, AL
Posted: Sun May 26, 2013 5:59 pm Post subject:
Annimator and Ring Mod Question |
I'm working on several of the Yusynth projects. Wow, thanks a ton. I can't believe how awesome and informative these things are to those of us just starting. THANK YOU!
1) On the Saw animator there are 12 100k resistors listed on the BOM. On the PCB I received from bride chamber the one nearest the edge of the PCB (R13?)is shown as a 10k on the PCB. Unfortunately, I can't read the circuit well enough yet to know which R# it really is. It's the one just to the right of CV1 and at the edge of the PCB. Anyhow, is that a typo on the PCB, or did that get turned into a 10K?
2)On the Dual Ring Modulator, I couldn't find 220 Ohm trimmers. Is something larger like a 250 or 500 ok?
Thanks for any help you can provide
Jeff |
capicoso
Posted: Sun May 26, 2013 9:55 pm Post subject:
Re: Annimator and Ring Mod Question |
For the saw animator, http://yusynth.net/Modular/Commun/SAWANIM/sawanim-COMP-LAY2.jpg
i suppose it's 100k. On the schematic R13 is 100k, usually the typos are in the pcb layout, always refer to the schematic since it's the original... the others are adaptations from the schematic, and errors can happen
for the ring modulator 250 is fine |
yusynth
Posted: Mon May 27, 2013 1:13 am Post subject:
As capicoso says _________________ Yves |
jmcecil
Posted: Mon May 27, 2013 6:07 am Post subject:
thank you! |
jmcecil
Posted: Wed May 29, 2013 6:00 am Post subject:
hmm ... closest trimmer I can find is 500 ohm. Is that to far out of range? |
yusynth
Posted: Wed May 29, 2013 7:57 am Post subject:
yes it's too high _________________ Yves |
jmcecil
Posted: Wed May 29, 2013 8:04 am Post subject:
figured you'd say that
No one seems to carry them in the US. The only ones in the 200->400 ohm range are the tripod kind. I have a bourns part number, but they don't seem to be carried by anyone.
Anyone know where you can get a 220 ohm trimmer in the US? |
jmcecil
Posted: Mon Dec 23, 2013 10:15 am Post subject:
sorry to resurrect this topic, but I still can't find a 220 ohm trimmer anywhere. I've even tried contacting Bourns directly ... I can buy a lot of 1000 from them
Anyone have a clue where to source a couple 220 ohm trimmers? I've tried 200 ohm, but can't get it to go anywhere near silent during the trimming process. Any help would be appreciated. |
yusynth
Posted: Mon Dec 23, 2013 10:47 am Post subject:
You may try using a 500 trimmer and use a 270 ohm resistor connected between the extreme legs of the trimmer, this way the circuit sees the good resistor value.
Otherwise I checked on the Mouser's site and there are some product references :
652-3296W-1-221ALF
652-3296W-1-221LF
652-3296Y-1-251LF
652-3296X-1-221LF _________________ Yves |
jmcecil
Posted: Mon Dec 23, 2013 11:15 am Post subject:
yusynth wrote: | You may try using a 500 trimmer and use a 270 ohm resistor connected between the extreme legs of the trimmer, this way the circuit sees the good resistor value.
652-3296W-1-221ALF
652-3296W-1-221LF
652-3296Y-1-251LF
652-3296X-1-221LF |
Thank you for the reply ...
From what I can see, those are the parts that I can order in quantities of > 1000. I had actually contacted Mouser directly, and they tried quite hard to find some for me. They were really helpful and even suggested I try Bourns through a "demo" program.
Anyhow, if I read your suggestion correctly, I can take 1 270ohm resistor and solder it to the two outside legs of the 500ohm pot? I think I have both of those parts handy.
Thanks again ... I've built quite a few of your modules! I can't thank you enough for your site and info. |
gregcomposition
Posted: Mon Dec 23, 2013 5:10 pm Post subject:
Hi!
Maybe I'm wrong, but I think the popular 200 ohm trimmers could replace the 220 ohm? I used them in my Ring Modulator and they do the trick.
Ups, you wrote that you have tried it and it doesn't work. Sorry, I missed your previous post.
If not - I've done a little research - here you have a 250 ohm trimmer with a 1 piece minimum order quantity:
http://www.newark.com/bourns/3299w-1-251lf/trimmer-pot-250-ohm-10-25turn/dp/06X8985
Best regards,
Greg |
jmcecil
Posted: Mon Dec 23, 2013 5:20 pm Post subject:
gregcomposition wrote: | Hi!
Best regards,
Greg |
Interesting. You used 200s in for this project? I can't get the signal to go even close to negated. Maybe there is something else wrong in my build. |
gdavis
Posted: Mon Dec 23, 2013 5:33 pm Post subject:
jmcecil wrote: | gregcomposition wrote: | Hi!
Best regards,
Greg |
I think you have another problem. 220 vs. 200 shouldn't cause an issue. The trimmers have a 10% tolerance anyway which means that a 220 ohm could actually be as low as 200. _________________ My synth build blog: http://gndsynth.blogspot.com/ |
gregcomposition
jmcecil
Posted: Tue Dec 24, 2013 7:33 am Post subject:
I appreciate the information. I should mention that I am getting Ring action. I just have a lot of bleed. So that's why I thought it was a trimmer problem. But, I'll go back through and see if I have something else screwed up. |
