  electro-music.com June Solstice Concert Various Artists
G2 Audio Interrupt on Patch change?
Page 1 of 1 [7 Posts]
adnauseam
PostPosted: Sun May 26, 2013 10:09 pm    Post subject: G2 Audio Interrupt on Patch change? Reply with quote  Mark this post and the followings unread
So I have a G1. One character of the G1 is that the audio is disturbed when either adding new modules or changing patches.
Is this also evident with the G2?
Couldn't find any posts on / didn't know what to search for
Curious.
Thanks in advance.
G2 patch files: 625
PostPosted: Sun May 26, 2013 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. Patch change interrupts audio but each patch has 8 variations which can be changed without a glitch. Do they have variations on the g1?
adnauseam
PostPosted: Sun May 26, 2013 10:39 pm    Post subject: G1 Variations Reply with quote  Mark this post and the followings unread
No, the G1 has no variations! The G1 is VERY minimal in many regards compared to the G1.
Almost had a G2 tonight. I guess patience is a virtue.
Audio files: 336
PostPosted: Mon May 27, 2013 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
The sound interruptions are actually slightly worse on the g2, as that unit occasionally reconfigures modules when you add patch connections on modules that you have already placed. On the g1 sound only stutters when you add or remove modules.
adnauseam
PostPosted: Mon May 27, 2013 9:15 pm    Post subject: G2 Audio Interruptions Reply with quote  Mark this post and the followings unread
The audio interrupts can be pretty frustrating. The timing of the oscillators is definitely interrupted when changing patch modules in the editor. This is especially evident during FM-type synthesis that relies upon the synchronization of these oscillators.
exeterdown
PostPosted: Thu Dec 26, 2013 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ha, yea I sometimes get a weird unison type sound when deleting modules.
Haven't tested it but I will if no one beats me to it...
Does the glitch happen in slot B if you change preset on slot A?
Electromagnetic Wave
G2 patch files: 30
PostPosted: Sat Dec 28, 2013 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
the polyphony must be recalculated for all slots
