  Twyndyllyngs Live in person Chez Mosc
PCB offer: Thomas Henry's CMOS ADSR (blinkin' lights)
Page 2 of 3 [54 Posts]
smidirin
PostPosted: Wed Jul 24, 2013 4:56 am    Post subject:   Reply with quote  Mark this post and the followings unread
thanks fonik, got pcb's & they're your usual top quality Cool
StormB
PostPosted: Thu Aug 15, 2013 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it still possible to get 2PCB CMOS ADSR
crashlander42
PostPosted: Sat Aug 31, 2013 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I have no idea what I've done wrong with this module. It doesn't seem to want to trigger in the right order in gate mode (A-R-D) and then A-R-D-S in trigger mode. I've repeatedly gone over my wiring and can't figure this one out.
Anyone else run into anything similar or am I just stupid?
When they plug me in the lights go down in Hong Kong.
http://www.myspace.com/isaciongun
http://www.youtube.com/user/Crashlander42
My DIY stuff Flickr
PostPosted: Mon Sep 02, 2013 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
most important, use CMOS capable of +15V, and definetely use a CMOS timer, as shown on the BOM. a common 555 won't do.
additionally, a valued customer recently spotted an error on the circuit PCB. i did not recognize this error just because the two prototypes i built worked flawless from the start w/o any corrections.
The minor error on the PCB routing: +V is connected to IC2/pin8 (CMOS Timer) via C7, however, this capacitor should be mounted in parallel. So here is the fix:
fonitronik at
crashlander42
PostPosted: Mon Sep 02, 2013 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll give that a try. I'm using the ICM7555, which worked fine on the LFO's, so I'd assumed it would be fine here.
My DIY stuff Flickr
crashlander42
PostPosted: Mon Sep 02, 2013 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Weirdest thing. No matter what it seems to get to sustain and just stop.
My DIY stuff Flickr
PostPosted: Wed Sep 04, 2013 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
the multiplexer is addressed by the gate input and the timer. so i suspect the 555 to not working properly.
did you apply the fix yet?
fonitronik at
crashlander42
PostPosted: Wed Sep 04, 2013 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I applied the fix. I'm going to replace the 555 when I get home from work with a new TLC555 and see if that does it.
My DIY stuff Flickr
StormB
PostPosted: Thu Sep 05, 2013 1:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
just yesterday my CMOS ADSR soldered and finished
found that it works great with einemTLC555 or NE555
then when I tried it with an ICM555 the envelope curve does not work properly
PostPosted: Thu Sep 05, 2013 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
StormB wrote:
Hello
this is great information. and thomas obviously listed especially the TLC555 part in his BOM.
fonitronik at
crashlander42
PostPosted: Thu Sep 05, 2013 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
StormB wrote:
Hello
Well, that explains a lot, and is a hard lesson on why I should always use sockets for my chips.
My DIY stuff Flickr
crashlander42
PostPosted: Thu Sep 05, 2013 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
SO I replaced my ICM7555 with a TLC555 and I'm getting the same result. It just stops at Sustain and stays there.
I'm going to build my second board out and see how it works.
My DIY stuff Flickr
crashlander42
PostPosted: Thu Sep 05, 2013 9:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, so now it works as expected with a gate, but when it gets a trigger or I try to use it as an LFO it stops at sustain.
With a gate signal it works fine.
My DIY stuff Flickr
PostPosted: Thu Sep 05, 2013 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
crashlander42 wrote:
..., but when it gets a trigger or I try to use it as an LFO it stops at sustain.
this is intended.
take a look at the top right corner of thomas schematic, where he explains the different modes:
if you apply just a trigger, then you are in AD mode. and that"s what the LFO mode switch does, it routes the end trigger to the trigger input. so in LFO mode you have a looped AD.
fonitronik at
PostPosted: Thu Sep 05, 2013 9:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh wait. it STOPS at sustain? turn the sustain fully down.
fonitronik at
crashlander42
PostPosted: Thu Sep 05, 2013 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup, it stops at sustain when I give it a trigger or use the LFO switch. I have it sustain turned all the way down and I've jacked around with the Trimmer.
My DIY stuff Flickr
PostPosted: Sat Sep 07, 2013 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
so all is good, but it just would not loop, no?
did you try patching the end trigger to the trigger input using a patch cord ISO the switch?
fonitronik at
crashlander42
PostPosted: Sat Sep 07, 2013 9:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nope. I tried manually patching it first. I populated both boards at the same time, so I probably did the same stupid thing on both of them. Sad
My DIY stuff Flickr
PostPosted: Sun Sep 08, 2013 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
i would try to test the end trigger. look at a scope, or just try to trigger another module with it.
if i understood you correct anything else is working? so you can use it with an external trigger in AD mode (trigger only, sustain & release fully down)?
fonitronik at
crashlander42
PostPosted: Sun Sep 08, 2013 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
With a gate signal it seems to work fine, with a trigger it goes through A-D and then sticks on sustain even if i have sustain and release fully down.
I looked at the end pulse out on my scope and I see nothing. I'm going to go back over the board and make sure I didn't do any stupid resistor mix-ups on both boards.
I may just be spoiled by everything I've built lately working perfectly right when I plug it in Smile sorry for the questions.
My DIY stuff Flickr
PostPosted: Sun Sep 08, 2013 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
so the AD mode is working properly for itself. it is just the the loop does not work?
just to be sure: for making it loop you must not have anything applied to the trigger input (unless you want to loop it by pathing the end trigger with a patch cord).
is is a very short pulse. try triggering another module (i.e. sequential switch or sequencer or divider) to be shure.
no need to be sorry! we will work it out.
fonitronik at
crashlander42
PostPosted: Sun Sep 08, 2013 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just tried running my sequential switches and sequencer with the end pulse and nothing. Even while repeatedly triggering via gate.
My DIY stuff Flickr
PostPosted: Mon Sep 09, 2013 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
now you know where to troubleshoot. there is somthing wrong with the comparator creating the end pulse. no end pulse, no loop in AD mode (LFO)
take a look at the circuitry in my additional documentation. check if the comparator output changes when envelop goes down.
fonitronik at
alangave
PostPosted: Sun Oct 20, 2013 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I know, I'm a bit late on this thread, but I wonder, Is it still possible to get 1PCB CMOS ADSR + front pannel ?
Regards
PostPosted: Thu Dec 12, 2013 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
alangave wrote:
Regards
yes.
fonitronik at
