ashleym
Posted: Wed Sep 11, 2013 2:25 pm Post subject:
Dave,
What a good idea..........
The Wasp filter has plus and minus CV inputs. The CGS matrix mixer has plus one way and minus the other controls too. So it is sort of covered. With my design I keep the attenuators separate from the modules so I can mix the CV levels with mixers or use simple passive attenuator and stack some bananas. This is in the spirit of Moog modulars.
You say you possibly send the ADSRs into the VCO. Have you thought of using a couple of these, one for each VCO?
http://www.muffwiggler.com/forum/topic-64769.html
Giving +/- options to modulation. If you think they would be useful drop me a PM _________________ http://soundcloud.com/for-mash-get-ash |
Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
Audio files: 155
Audio files: 155
Audio files: 155
Audio files: 155
Audio files: 155
Audio files: 155
Audio files: 155
Audio files: 155
Posted: Tue Oct 15, 2013 11:50 am Post subject:
Hi
Wiring has started , first job, the 2 mfos vco's transplanted from the blue modular to this synth , then the dual frequency dividers (Roman Sowa) for vco 1 & 2 sub osc's , Ken Stone simple wave folder for vco 1 , 5Pulser (Ian Fritz) for vco2 , mixers for vcf1 & vcf2 (mfos simple mixers) and a couple of buffers to send the sum of mixer1 to vcf2 and vice-versa (that gives the option of 2 vco's to either vcf).
Also have the mfos 24dB filter & 12dB svvcf wired in with a toggle switch to route vcf1 cutoff control to vcf2 cutoff for twin sweeps with the one dial.
Just bolted on the filter ADSR's which i need to lengthen a couple of leads.
pcb's & veroboards made already but still to hook up...
dual vca.
vca ADSR's.
6-lfo's.
noise circuit.
S & H.
Burst generator.
FX600 multi-FX.
RAT distortion.
a few pix of what's been soldered so far.
Description: |
Filesize: |
321.72 KB |
Viewed: |
414 Time(s) |
Description: |
Filesize: |
247.38 KB |
Viewed: |
433 Time(s) |
ashleym
Posted: Thu Oct 17, 2013 1:27 am Post subject:
Part of me likes the front of your synth and the other part likes the jumble of wires and boards on the back!! I think that says more about me than you.
Good build. Keep up the flow of pictures please. _________________ http://soundcloud.com/for-mash-get-ash |
Paradigm X
Joined: Feb 15, 2011 Posts: 363 Location: Null and void
Posted: Thu Oct 17, 2013 5:05 am Post subject:
yeah, cool stuff skrog, amazing how quick you work |
Audio files: 155
Posted: Thu Oct 17, 2013 1:11 pm Post subject:
Thanks Ash ,
how is your filter module coming along ? |
Audio files: 155
Posted: Thu Oct 17, 2013 1:16 pm Post subject:
Paradigm X wrote: | yeah, cool stuff skrog, amazing how quick you work |
Thank you , as long as i take a rest from wiring regularly then im ok with concentration levels |
ashleym
Posted: Sat Oct 19, 2013 4:41 pm Post subject:
Skrog Productions wrote: |
I am awaiting the final PCB from the Bridechamber, a CS80 board. In the mean time I have just filled a couple of Fonik Henry Thomas 555 envelopes. Unfortunately I have run out of my scraps of Molex connectors etc etc so I have just put in a Rapid order. Also because I need some vatrols and odd chips an order has gone in to Farnell........
These are ADSRs you can loop and turn into LFOs and they have an LED for each stage....mmmmm.....lights
Of course with MTA type power connectors there are the headers for this and a crimp tool. I am filling up with different crimp tools. Do I need them? Sort of, they make life a lit easier and I like a tool
I also try to avoid the eBay chip purchase but sometimes this cant be done, especially as some of the module designs stick with the older chips from the original design. 3080s in the EDP Wasp filter as still pretty easy to get but the 3280s for the CS80 filter are a little more rare. And I do want to get one that works!! _________________ http://soundcloud.com/for-mash-get-ash |
Audio files: 155
Posted: Sat Oct 19, 2013 5:31 pm Post subject:
, yes , if i have no luck with cricklewood electronics London for any chips that rapid or farnel don't have , i too order from HongKong , only takes a couple of weeks to come, bit like royal mail
Wires wires wires , just enough room to fit boards 18 / 19 & 20 on the white "L" bracket (2"x 2" Electrical containment pvc trunking sawed to length & bolted to panel) .
Couple of silly faults found only on my veroboard circuits .... 2 surplus isolator holes , bridged now and a resistor leg in the wrong hole, fixed now , and a red faced moment when the 6 lfo's were pulsing crazily and randomly , yes, i had not connected the 0V ground tail wire for all the pots to 0V at the supply , deary me , heh , nevermind .
Here is another pic at the latest stage , getting busy round the back of the panel now.
Description: |
Filesize: |
546.96 KB |
Viewed: |
280 Time(s) |
Joined: Apr 03, 2004 Posts: 24083 Location: The Netherlands, Enschede
Audio files: 278
Posted: Sat Oct 19, 2013 6:27 pm Post subject:
Nice space ship
and a great picture that too _________________ Jan
Audio files: 155
Posted: Wed Oct 23, 2013 10:38 am Post subject:
thanks Jan |
Audio files: 155
Joined: Dec 11, 2010 Posts: 966 Location: Toronto, Ontario - Canada
Posted: Wed Oct 23, 2013 11:49 am Post subject:
How are the boards supported? It looks like it might be a lot of weight on the larger boards if they are only supported at the front. _________________ JacobWatters.com |
Audio files: 155
Audio files: 155
Audio files: 705
Audio files: 155
Posted: Sat Oct 26, 2013 5:51 am Post subject:
Heh , do you think the fx chip would catch fire if i changed between fx at audio rates |
Audio files: 155
Posted: Mon Oct 28, 2013 11:44 am Post subject:
Hullo
I connected all the power connections and hooked up to the modular supply's Raw DC output yesterday , No magic smoke , hurrah , had 5 trips from studio to soldering workbench to fix several little errors on my part , only 1 of my veroboard circuits playing up , the mfos micro-sample n hold , i robbed an LF444 from my soundlab++ to try it out , great triggers coming from it , but a rather lame cv with no stepping , i'll take a look at all my tracks with a magnifying glass , likely a sliver of copper somewhere , or something else silly.
Left the synth running for 3 hours yesterday and i do need some air flow around the 12v heatsinks , trip to the local DIY store for a couple of 50mm round, push in air vents & try to find the 50mm holesaw in the work van.
Final pix to come and sounds after the weekend.
Dave. |
