"Blacet time Machine" regen issue
xbstoller
PostPosted: Tue Jun 11, 2013 5:23 pm    Post subject: "Blacet time Machine" regen issue
Subject description: help - Regen Pot needs adj -at most counter clk-wise its = max regen
help - Regen Pot needs adj -at most counter clk-wise its = max regen !?!
I just recieved a new per-built "Blacet time Machine" and its needs its Regen setting adjusted -
Problem: Regen setting turned all the way clk-wise it doesrt reach max feedback -- but at the most counter clk-wise its at max regeneration(for a tinny bit -at 0 - )-- it should be at max regen at most clk-wise position --i suspect this is adjusted w/ on of the trimpots but Im not sure which one to be tweaking on -- anyone familar with this and can point me to - have a schemo and regen is a 50k pot that has 10v to ground - perhap the pot is bad ?
synthcube
PostPosted: Tue Jun 11, 2013 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
the regen pot should be set to 'center' normally to eliminate regen effect.
(some versions have a center detent pot)
web store: www.synthcube.com/cart
we've acquired MFOS to help carry on Ray Wilson's work: www.musicfromouterspace.com
xbstoller
PostPosted: Tue Jun 11, 2013 9:20 pm    Post subject: the regen pot should be set to 'center' normally to eliminat
Subject description: the regen pot should be set to 'center' normally to eliminate regen effect.
ah - im and idyot - its too dark dwnstairs and i didnt notice the ctr detent and misunderstood the function ... so ah... -- um ..ah ,,thanks for the reply and clarification!
