How can I use presets for an STK instrument?
gersart
PostPosted: Tue Jun 18, 2013 8:05 pm    Post subject:  How can I use presets for an STK instrument?
Subject description: Trying to figure out how to use Glass Harmonica and Tibetan Bowl
I like chuck. it's cool. While searching through the various web links and pages for the Bowed instrument I found some interesting things alluding to instrument presets, including Glass Harmonica and Tibetan Bowl.
http://chuck.cs.princeton.edu/doc/program/ugen_full.html
Like all cool things, there is no real help in the examples for this kind of information.
Can someone shed some light on how I might go about incorporating the awesomeness of a glass harmonica or tibetan bowl for a project...? Or am I destined to never truly know...
thank you muchly... Very Happy
Audio files: 350
PostPosted: Sat Jun 22, 2013 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome gersart!
Have a look at examples/stk/mode-o-matic.ck
Search for the string "preset" in there. It uses another UGen (ModalBar), but the principle should be the same.
Preset is just another input on the UGen, like freq or gain. According to the docs, the glass harmonica preset is found in the BandedWG UGen, and you would set that like this:
BandedWG waveguideOscillator;
2 => waveguideOscillator.preset; // 2 for glass harmonica
Hope that helps.
gersart
PostPosted: Mon Jul 08, 2013 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply.
I've explored quite a bit over the last little while, including figuring out how to make my own classes for instruments. I also discovered the usefulness of the presets (I was trying to use the BandedWG presets in the Bowed class, which wasn't working quite right)
It's very much an exploration of techniques. I kind of wish I could find some examples of the different bowed instruments to understand how the values change the character of the instrument (what makes a cello different than a violin, for instance)
More research is necessary, I guess.
Antimon wrote:
welcome gersart!
Hope that helps.
