Mixer needed for...
El Mop
PostPosted: Tue Jul 02, 2013 1:18 pm    Post subject: Mixer needed for... Reply with quote  Mark this post and the followings unread
This question is pretty similar to my last, so I can guess the answer(s), but anyway, here it is:
I am building a synth which has a switch for each waveform of an oscillator, so you can use any of the waveforms together (like the oscillators of the Sequential Prophet Pro One/Pro 5).
Do I necessarily need a mixer to to add the outputs of the waveforms and what would be the disadvantage of skipping the mixer?
Thanks for your help!
gdavis
PostPosted: Wed Jul 03, 2013 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you want to use any of the waveforms together then yes, you should probably have a mixer. In fact, I think I would forgo the switches and just have a level control for each wave form so you can blend in as much as you want of each.
Without a mixer the oscillator outputs are effectively shorted together, possibly blowing the op amps if there isn't enough current protection.
El Mop
PostPosted: Sat Jul 06, 2013 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
Level Control would also cool!
