Andromeda arpeggiator -- is there an "as played" mode?
bluecloud
PostPosted: Sat Jul 13, 2013 11:09 pm    Post subject: Andromeda arpeggiator -- is there an "as played" mode?
Subject description: Only 4 supported arpeggiator types is very limited
Testing out the arpeggiator on my Andromeda I only see 4 modes available:
- Forward
- Reverse
- Up/down
- Up/Down 2
Needless to say this is quite limiting and gets boring quickly.
1. I don't see a RANDOM mode or an "AS PLAYED" arpeggiator mode. Do such modes exist?
2. If so, how to access them from arpeggiator menu?
3. Any other arpeggiator settings avail to not make it sound so precise/predictable? ie... swing, quantization settings etc?
Many thanks for any help!
sunny pedaal
Audio files: 12
PostPosted: Sat Jul 27, 2013 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
page 80 of the manual, that's it ( slightly bit more then you describe )
normal stuff for an analogue synth, little indeed for a computerbased system
it's the way it is
