<on air> PHOBoS music from project "droning" by Louigi Verona
CGS Steiner Parker problem: no control over cutoff
Page 1 of 1 [2 Posts]
codenamerofl
PostPosted: Fri Jul 19, 2013 2:41 am    Post subject: CGS Steiner Parker problem: no control over cutoff Reply with quote  Mark this post and the followings unread
hi all,
built a CGS ver 1.3 steiner parker sythacon filter on protoboard. no shorts, no smoke, it's filtering, has good output, resonance changes gain and is working from what i can tell, and the trimmer adjusts the lowest cutoff point.
however, the cutoff pot will not change the cutoff frequency. i am stumped as to why. i have quadruple checked the transistors and they are wired up right. i have tried different pots, and still nothing. the 1uF cap at the junction is correctly orientated.
anyone have a guess as to why the frequency will not change? my brain is fried. been staring at it for 6 hours for two days now.
thanks for any help
prgdeltablues
Audio files: 12
PostPosted: Fri Jul 19, 2013 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried disconnecting the cut-off freq pot and the CV mod pot, and apply a few volts directly to the end of the 220k resistor (where the wiper from the pot would have connected)? And check that you have resistance across the span trim pot - if that is shorted, then obviously the base of the first npn would be being held at ground. Always hard to tell without calculating in a complete circuit, but you should have a bit under 1k across that trimmer.
Peter
