USB MIDI instruments dropping out?
Page 1 of 1 [7 Posts]
laura woodswalker
Audio files: 12
PostPosted: Wed Sep 11, 2013 6:50 am    Post subject: USB MIDI instruments dropping out? Reply with quote  Mark this post and the followings unread
TECHNICAL QUESTION. I have had a problem with instruments 'dropping out' during performance. I have Ableton 9, a core i5 laptop, a SLMKI MIDI controller, a Novation Ultranova hardware synth which I also use for MIDI instruments, a Launchpad and an AKAI Mini. Frequently when I am playing a set, I get no sound from the Launchpad User 2 (which is mapped to Reaktor or some kind of noise patch) or from the AKAI Mini, which is usually mapped to Absynth. In fact, several times while playing I could get no audio from my Ultranova hardware synth.
Playing clips on a track definitely seems to interfere with using that instrument in realtime. Is this to be expected?
I have a USB hub with 6 slots, and I am using 5 of them. The USB hub is run thru a Tascam audio interface.
So the question is WTF?? I am wondering if one of these devices is malfunctioning and the USB signals are intermittently not getting thru. The candidates are 1) the audio interface 2) the USB hub, or 3) the SLMKI midi controller. Oh yeah, maybe Ableton is the problem.
Does anyone have a suggestion? Because otherwise I will either have to 1) get rid of an instrument and just record clips for that part, or 2) add my hardware mixer to the set and run my hardware synth thru that, thus removing it from Ableton and reducing the USB load. Or buy new gear in hopes that will solve the problem??
Thanks for your help folks! Smile
PostPosted: Wed Sep 11, 2013 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry if this is obvious, but have you checked for midi loops, especially in Ableton Live? Go into preferences, the "MIDI Sync" tab. Are any of the devices you are having trouble with listed as both input and output in the track column? Could you try removing so that you only have either input or output for each?
If you want to use something as both in and out, make sure that tracks that send data to the instrument aren't armed. Either that or turn off local keyboard in your synth, if that's possible (it is sometimes).
If you use other programs for routing midi you might want to check that over so it doesn't mess things up in combination with Live.
laura woodswalker
Audio files: 12
PostPosted: Wed Sep 11, 2013 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks... I don't have my rig turned on right now (I'll turn it on later) but according to my notes I do have all the devices set to 'in' and 'out'. I thought that that was what enabled them to receive note data, i.e. me playing the keys.
If my settings are the problem, then why is the problem INTERMITTENT? Sometimes all the devices work fine. Usually when I'm at home practicing. Get me up there playing a set, and my launchpad or Akai won't play & I'm stuck with half my sounds missing.
Not fun. Sad
PostPosted: Sat Sep 14, 2013 8:49 am    Post subject: Re: USB MIDI instruments dropping out? Reply with quote  Mark this post and the followings unread
Do you have the problem if you run the usb hub directly into the computer instead of through the audio interface?
PostPosted: Sat Sep 14, 2013 8:58 am    Post subject: Re: USB MIDI instruments dropping out? Reply with quote  Mark this post and the followings unread
I assume when this happens you are monitoring the audio through the audio interface. If you have a headphone output on the Ultranova, does the audio cut out there, too, or just through the Tascam?
laura woodswalker
Audio files: 12
PostPosted: Sat Sep 14, 2013 12:53 pm    Post subject: Re: USB MIDI instruments dropping out? Reply with quote  Mark this post and the followings unread
I don't think I could run it directly to the computer because I am running 4 USB instruments.
But I spose I could try this just as a test.
laura woodswalker
Audio files: 12
PostPosted: Sat Sep 14, 2013 12:58 pm    Post subject: Re: USB MIDI instruments dropping out? Reply with quote  Mark this post and the followings unread
It generally happens when I am playing my whole set. Launching Ableton clips, etc. I haven't tried putting on headphones at that point, but sure that is a great thing to test.
One thing I did try: my MIDI channel settings. Generally I have my Launchpad set for Channel 5 and the AKAI mini at channel 4. This is so I don't have conflicting MIDI CC messages with the SLMKI which is the main controller.
However, Ableton does have a setting "All channels". I tried that with my AKAI and the sound was fine.
So, is there a possibility that the sound was cutting out just because of a wrong MIDI channel? (again: when i do a sound check on each instrument itself,, all the instruments play just fine.)
