Test clip question
rogerlatur
PostPosted: Sun Sep 22, 2013 9:44 am    Post subject: Test clip question Reply with quote  Mark this post and the followings unread
Do you know what comes on the other side of the test clip ?
Banana is not mentionned either.
http://www.mouser.com/ds/2/159/d3925_k4176_k5522_1_01-66165.pdf
I look first at this one because the ones with cable are much more expensive.
May I ask what you do use for testing pcb without soldering wires ? For instance when you do not want yet to solder the pots.
gdavis
PostPosted: Sun Sep 22, 2013 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
That's just a clip. There is no "other end", what you see is what you get. You have to attach your own wire (not sure how that's done).
I think this is what you're looking for:
http://www.mouser.com/ProductDetail/Pomona-Electronics/5523/?qs=sGAEpiMZZMtTOasXncsdUSyEpyO6wEB1lA8Dq9Yv1I0%3d
Not much more than the cost of the equivalent number of clips.
I use something similar but with alligator clips instead of minigrabbers. Not necessarily any better, just something I happened to pick up one day when I was at Radio Shack. In fact I've considered picking up a set of those.
rogerlatur
PostPosted: Sun Sep 22, 2013 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I use something similar but with alligator clips instead of micrograbbers. Not necessarily any better, just something I happened to pick up one day when I was at Radio Shack. In fact I've considered picking up a set of those.
I have alligators but I would like to have the possibility to "connect" to the pcb holes, so I do not need to solder wires or pots to the board or testing before mounting.
If it cannot be connected to anything, in this case alligators are indeed a better solution.
So I will go for the clip to clip cables.
Thank you !
