Need a stripboard layout for a Noise generator 9v
Page 1 of 1 [13 Posts]
citric acid
PostPosted: Thu Sep 26, 2013 12:15 pm    Post subject: Need a stripboard layout for a Noise generator 9v Reply with quote  Mark this post and the followings unread
i need a noise generator Stripboard layout. does someone has one ?
I have a lot of synths without a noise source, like little phaaty minitaur etc. this synths have a external in. for live gigs i don't wan't to use modules , so i wan't to build a box with 1 or 2 dif. noise white and or pink noise. just to put it in to the external in. the best is to use it with a 9v battery etc...
does any one have an idear or can help me.
that will be great.
http://soundcloud.com/citric-acid-303
mush
PostPosted: Fri Sep 27, 2013 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
this is a simple circuit that you should be able to transfer to stirpboard without any problems:
http://www.electro-music.com/forum/topic-37453.html
should work with 9v without any major modification.
Nardu
PostPosted: Fri Sep 27, 2013 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
You may try also :
http://www.eeweb.com/blog/extreme_circuits/simple-white-noise-generator
http://yusynth.net/Modular/EN/NOISE/
http://nardusynth.blogspot.ro/
bubzy
Audio files: 63
PostPosted: Fri Sep 27, 2013 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
you might find some problems as most noise gens work at higher voltages. I needed one for a percussion circuit running at 5v and eventually had to program a PIC to do the noise for me. "bit" annoying....geddit? bit..... hahahaha
*fades into a darken corner to let the humour linger*
_Richard_ Smile
Nardu
PostPosted: Fri Sep 27, 2013 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
5V ? , try here :
http://www.electricdruid.net/forums.html?page=projects.noisegen
9V - here :
http://www.simonthenerd.com/files/wp20/WP-20b.bmp
bubzy
Audio files: 63
PostPosted: Fri Sep 27, 2013 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
in the "9v" one you posted, the actual noise gen part of the circuit is running off +18v !!
_Richard_ Smile
Nardu
PostPosted: Fri Sep 27, 2013 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
+18v ? For ex. see here :
http://www.talkingelectronics.com/projects/50%20-%20555%20Circuits/images/VoltageDoubler.gif
http://www.eleccircuit.com/wp-content/uploads/2010/05/doubler-voltage-12vdc-to-24vdc-with-ne555.jpg
- Below , a striboard version for Simmons SDS3 noise circuit from http://www.electro-music.com/forum/topic-37453.html
Stripboard for Simmons SDS3 noise circuit
 Filesize:  162.48 KB
 Viewed:  260 Time(s)
citric acid
PostPosted: Sat Sep 28, 2013 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for all replays:) now i have a lot. i think the sds one is cool. thanks
rossics
PostPosted: Sat Nov 23, 2013 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a simple one, I couldn't find a stripboard of this circuit online so quickly made one up. works fine
White Noise Generator Stripboard
 Filesize:  33.26 KB
 Viewed:  304 Time(s)
richardc64
Audio files: 26
PostPosted: Sun Nov 24, 2013 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Abolutely! I've gotten a similar circuit to work at slightly less than 9V. Selecting the noisiest transistor was hardly necessary. I tried two random '3904s and a 2222 for the reverse biased transistor and got equal noisiness.
citric, isn't it a little premature to ask for a layout before you've decided on a circuit?
 Filesize:  3.26 KB
 Viewed:  12354 Time(s)
citric acid
PostPosted: Mon Nov 25, 2013 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks.
i just need a simple noise. So thats why i ask for a stripboard. The circuit doesn´t take sense for my needs. I use this just for live situations where i don´t have a noise source. i wan´t to feed my mono synths with noise. myby my minitaur etc have no noise source and i will feed them with external noise. and i think a lot of people have ready circuits and more skills than me. i tought it was ok to ask for it Smile if it was not ok, sorry for this.
many thanks for you help. verry friendly
richardc64
Audio files: 26
PostPosted: Mon Nov 25, 2013 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
No apology necessary. We all sometimes get ahead of ourselves when we want to build something.
predok
PostPosted: Sun Nov 29, 2015 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi all! I have a problem with 50 hz hum which present in EVERY white noise generator that I've build. I've tried few schemes. Where is it came from? It's not a sound card (i've tried different cards and amps and cables). It's not a power supply (at the picture bellow scheme is powered with 9V battery).
 Filesize:  224.42 KB
 Viewed:  128 Time(s)
