Offset biasing in OTA's (LM13700) in DC-coupled applications
Page 1 of 1 [14 Posts]
codemode
PostPosted: Mon Oct 14, 2013 1:52 am    Post subject: Offset biasing in OTA's (LM13700) in DC-coupled applications
Subject description: designing VCA's for synth control
I have spent a couple days trying to design a VCA to have CV control over the modulation amounts of envelopes and LFO's. Basically, the control voltage to the VCA will control the depth of the modulation source.
One of the main destinations for modulation will be a VCO. The problem I have is with offset biasing in the OTA. As the control input is varied, the DC offset in the output varies. I can try to minimize this by trimming the input of the OTA but it doesn't get rid of it by any means. There can be 100mV or more of offset depending on the control voltage, and it doesn't seem to vary linearly (there's a big bump in offset right in the middle of CV range). Since the VCO is 1V/Oct (83mV per semitone) I don't want more then 5mV offset or the fundamental pitch of the VCO will change several cents or even semitones depending on the modulation amount!
I have tested some circuits based on the LM13700 both in LTSPice and in the lab. The results for both sim and proto are exactly the same - too much offset. I want to use the LM13700 because they are cheap and still available, and they have a linear control input. The basic circuit is attached with description below.
Here's what I have done to this point.
    *scaled resistor values so that the 5Vpp envelope is attenuated to 25mV at the OTA input.
    *scaled the CV input so that the 0-3.3V control voltage gives 0 to 0.5mA to the OTA control input.
    *using an external op amp instead of LM13700 buffers. Feedback resistance is scaled for 1:1 output at full scale (5V VCA output for 3.3V CV input)
Certainly hundreds or thousands of you have done this before me! Is there any way to improve this? I've seen many commercial preset analog synths that use LM13700's for control VCA's, presumably with modulation destinations going to VCO's, or even controlling glide amounts. There must be some way to get the offset low enough?
 Filesize:  53.32 KB
 Viewed:  336 Time(s)
gdavis
PostPosted: Mon Oct 14, 2013 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh boy, I'm looking to do almost exactly the same thing, but I'm not quite as far along. Now you've got me worried.
Have you tried a 500ohm trimmer across the + and - inputs with wiper to ground (instead of your 220's and offset trimmer) as shown in the datasheet?
gdavis
PostPosted: Mon Oct 14, 2013 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, I'm playing with your circuit in LTSpice and not really seeing any offset issue that can't be fixed by the trimmer.
Couple things I did notice:
The 220k makes the trimmer a bit touchy, 1M seems to work fine.
60k seems to be to large for your 500uA Iabc to get Vout/Vin = 1. According to the math I think it should be 34k but 37k seems to work in simulation.
dunno
codemode
PostPosted: Mon Oct 14, 2013 7:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes I have, as you would expect it achieves the same end.
Today I simulated and tested a circuit based on the Mike Sims improved VCA that I've seen a lot on these pages. The idea is to improve THD and CV feedthrough. In its basic form it works ok. I was able to improve performance and get 5mV max offset by doing the following.
    * based on Mike Sims matched-OTA circuit
    * remember my design is scaled for 0 to 3.3 CV so components scaled appropriately.
    * keep Ibias below 0.3mA max. If I don't the offset starts going non-linear. Basically I find the offset jumps from 0V at a 0V CV input to 120mV at 3V CV input and down to -50mV or something like with a 5V CV input (equivalent to Ibias of 0.5mA). So if I keep Ibias between 0 and 0.3mA the offset is kind of linear.
    * Next, I feed a little bit if the CV to the inverting input of the OTA to scale the offset for increasing CV input. Doing this I can get an offset of 5mV max.
I have no idea if this is an appropriate solution or if there's an easier way or whatever but please let me know if you have any input.
 Filesize:  98.33 KB
 Viewed:  379 Time(s)
codemode
PostPosted: Mon Oct 14, 2013 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmmm, I bet you're right.
As I mentioned in both posts, I kept getting non-linearity in the CV bleedthrough when the Ibias goes above 0.3mA or so. Assuming this error maybe the offset would be somewhat linear when operating Ibias in the appropriate range. I'll test it as well.
codemode
PostPosted: Tue Oct 15, 2013 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
OK so I backed off on the control current and it works very well. You can see Figure 4 in the datasheet showing Vos versus Iabc and it does start to take off above 0.2mA so I think it makes sense. I tested the circuit as shown below and was able to calibrate the offset until it was inaudible with a raw square wave. For testing I grounded the VCA input and varied the CV from 0V to 3.3V. I actually had the CV sent to the pitch CV of a SEM module I had on the bench so I could also hear the results. Here's the actual offset I measured at various CV's...
0V = 100uV
1V = 360uV
2V = 200uV
3V = 110uV
3.3V = 140uV
so less than one cent in musical terms - which is great.
 Filesize:  70.89 KB
 Viewed:  237 Time(s)
gdavis
PostPosted: Tue Oct 15, 2013 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad to hear it. I remember some time back deciding on a max Iabc of 200uA but couldn't remember why Embarassed and the audio VCA circuits that I found on the net where hitting 500uA but I guess it's not really an issue for AC.
codemode
PostPosted: Tue Oct 15, 2013 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah exactly, the datasheet and all applications I've seen take advantage of Ibias up to 0.8mA to maximize performance in regards to SNR and THD. And for audio (AC) it's probably best case. For control VCA's I guess I was getting too cute.
gdavis
PostPosted: Tue Jan 21, 2014 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well there it is. I've finally seen this offset in my CV VCA. With trimming the best I can do is a hump in the middle of the CV range just like described above. And apparently at some point I decided Iabc of 500uA was a good idea, so I seem to be getting somewhere around 16 cents off at the VCO. Based on this discussion I'll try adjusting my circuit for 200uA Iabc, hopefully I'll get the same improvement.
gdavis
PostPosted: Wed Apr 16, 2014 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well that didn't work at all. I reduced Iabc and increased the output resistor value to maintain the same output voltage, and the offset was MUCH worse. Apparently any offset improvement is more than counteracted by the increased gain of the current to voltage converter. Maybe I should compensate for less Iabc by increasing the differential input instead of increasing gain on the output... Or is the input distortion going to be a problem then?
dougcl
PostPosted: Tue Dec 15, 2015 11:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi folks, I had pretty good luck following the advice in this thread and scaling back Iabc to 0.5mA max.
The problem I have now though is with the input jack floating (no cable connected) I want the input to default to 0 volts. Unfortunately the LM13700 input floats quite a bit. This shows up pretty accurately in the simulator. I tried a 1M pull down resistor on the input, but it can't drain enough current. In fact, it looks more like a 1k is needed to get an acceptable level, but that would give me a crazy low input impedance at the input jack. Seems like an op amp buffer on the input will solve the problem, but is it necessary? That's a lot of op amps.
brock
PostPosted: Thu Dec 17, 2015 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think an op amp on the input is the only way around the low impedance problem. I don't think I've seen an LM13700 VCA that doesn't have all inputs buffered is some way.
dougcl
PostPosted: Fri Dec 18, 2015 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks yeah I am looking at this now and it seems to make the whole circuit healthier.
dougcl
PostPosted: Mon Apr 04, 2016 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
On second thought, I am not so certain I solved anything. I think I merely retuned the input network to a much larger input voltage. This reduced the offset because I used less makeup gain, but led to unacceptable distortion.
I am unable to get both the distortion and offset down to acceptable levels simultaneously. Meanwhile the TI SPICE model is giving me wonderful predictions on both, but somehow off by a factor of 15x from the actual circuit. Worse however, the Iabc of one OTA is affecting the offset trim of the other (both OTAs in the same package). This happens with Iabc max of 500uA or 1mA. I haven't seen any mention of this online or in the datasheet. It is a deal breaker for me and the LM13700.
