CMOS Keyboard and Sequencer
jcintheus
PostPosted: Fri Nov 01, 2013 3:59 pm    Post subject: CMOS Keyboard and Sequencer Reply with quote  Mark this post and the followings unread
I finally got around to overhauling my CMOS keyboard.
http://electro-music.com/forum/topic-54141.html
While testing the sequencer I came up with this:
Here's a circuit description:
This circuit uses a 4067 as a 16 step sequencer. The ABCD inputs are controlled by a 4029 up/down, binary/BCD counter.
The up/down, and the Binary/BCD pins are controlled by a slow shift register(4015), this varies the ABCD count and randomifies the pitches, in terms of sequence.
The 4015 also controls the ABCD inputs of a 4089. The resulting pulses are then fed into the clock input of the 4029. This randomizes the rhythm of the sequence.
The filter-like sounds are created by a 4046 set up as a pitch tracker and modulated by another shift register(74HC273) and some resistors.
At the 2:00 mark you'll hear a 4017/4051 melody generator,
it's ABC inputs fed by the 4029 and the 4015. Also I added a bit of delay.
 Filesize:  1.21 MB
 Viewed:  174 Time(s)
JingleJoe
PostPosted: Sat Nov 02, 2013 9:48 am    Post subject: Re: CMOS Keyboard and Sequencer Reply with quote  Mark this post and the followings unread
thats incredible Very Happy
