2 Nord G2X's running together
Page 1 of 1 [8 Posts]
Moogfan
PostPosted: Sat Nov 02, 2013 11:18 am    Post subject: 2 Nord G2X's running together
Subject description: Nord G2X Heaven
Hello, I have the good fortune of having aquired two Nord Modular G2Xs AND a rack Nord Modular Expanded.
For the G2X's, I have each set to incremental midi channels 1,2,3,4 and 5,6,7,8 respectively using the first for musical parts, second for drums, arps, etc. Works fine in sequencing software as they are chained together via midi (thru). It is actually a dream come true.
Now, I realize this is a crazy question but, figured if anyone would know it would be from this forum. Is it possible to run 2 simultaneous instances of the G2 editor at the same time? I have each communicating on their own USB driver, and it seems to check out in the device manager. This is Windows 7 - 64 Home Profressional on a bootcamped Mac Pro
Lfohead
Audio files: 6
G2 patch files: 28
PostPosted: Sat Nov 02, 2013 12:50 pm    Post subject: Re: 2 Nord G2X's running together
Hi Moogfan
If i remember correctly its not possible..
PostPosted: Sat Nov 02, 2013 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Laughing Cool
No idea how this would work .. but at least .. when you copy and rename the exe you can run two editors ... prolly messy with the connections though as they each would grab all the USB ports I think ...
Moogfan
PostPosted: Sat Nov 02, 2013 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I have an answer, but it's going to take some testing on my end. I'm going to try using the open source editor on one, and the regular editor for the second. I've gotten them both to run simultaneously, but it's not exactly stable... yet.
Thanks for the replies, I'll keep on pluggin
UPDATE:
Actually, it's possible to run both together with the open source editor! All good now
PostPosted: Sat Nov 02, 2013 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great Cool
jamos
G2 patch files: 37
PostPosted: Sat Nov 02, 2013 7:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
You don't need two instances. One instance can show multiple G2s. (I have two.) Works great!
PostPosted: Sat Nov 02, 2013 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, three too - I had assumed OP to want two editors to be able to see more patches at the same time.
Estarriol
PostPosted: Wed Nov 06, 2013 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Got 2×G2X + G2exp too :-) Greetz to topicstarter ^_^. G2 editor does allow two G2's simulateneously, I've checked earlier.
