| Author | Message |
| fonik
|  Posted: Sat Jan 11, 2014 4:39 am    Post subject:
3rd run for Thomas Henry's 555-VCO and Controller LFO Subject description: taking orders until 26 JAN 14
| hi all,
 due to several requests i promised to announce another run of Circuit PCBs, frontpanel components PCBs (eurorack) and eurorack Frontpanels for Thomas Henry's latest Projects (VCO and LFO).
 so here we go. i will keep orders until 26 JAN 14.
 As always i won't take any money until the goods are ready for delivery.
 Please, tell me exactly what you wanted/needed, i.e.
 "1 complete set of VCO PCBs/Panels"
 or
 "2 circuit VCO PCBs
 + 1 frontpanel PCB
 + 1 euro frontpanel"
 you get the idea...
 don't hesitate to contact me if you are interested in a completed module(handmade for you).
 for the Eurorack Frontpanels i would need at least inquiries for a minimum of 30pcs, this is where the proce break kicks in. For less than 30 frontpanels i could not keep the price.
 more details about the nice 555-VCO:
 http://electro-music.com/forum/topic-56038.html
 more info about the awesome Controller LFO:
 http://electro-music.com/forum/topic-55470.html
 pricing unchanged:
 each PCB (circuit or frontpanel) = 7.50 EUR (~10.-USD)
 printed front panel = 10.-EUR  (~13.USD)
 shipping international:
 1 PCB = 2.-EUR (~3.-USD)
 2+ PCBs = 4.-EUR (~6.-USD)
 shipping deutschland:
 1 PCB = 1.-EUR, 2+ PCBs = 2.-EUR
   TH DIY Modules by fonitronik, on Flickr
 __________
 555-VCO BUILDING NOTES
 1)
 in the original schematic of the VCO frmo thomas henry we three times a resistor R26, whereas R25 is missing completely.
 so here are the values corresponding to the PCB labeling that are not covered correctly by the schematic/parts list:
 R25 - 300k
 R26 - 39k
 R55 - 5.6k
 2)
 when powering from 12V:
 R13 = 2k
 R27 = 22k
 R33 = 137k
 3)
 when you have a hard time finding a precision trimmer wit 25k, just use 20k. should do the job as well.
 4)
 Try several LM13700 for best sine. the amplitude might differ quite a bit!
 5)
 C4 is the timing cap. use a nice C0G/NP0 or a polysterene for better stability.
 6)
 Parts for the Control PCB
 for the pots any vertical mounted 3-pin 9mm pot should do, i used alpha and alps (for the values needed refer to thomas' schematic).
 for the jacks i used the PJ301-BM. there is a new high quality version available with berillium copper from
 THONK (Europe)
 or
 ERTHENVAR (USA)
 to connect the control board to the cicuit board you will need single row headers and receptables.
 if you build the VCO w/o the eurorack frontpanel components PCB you will have to manually wiring it up, which is a very reliable and easy to service solution IMHO. here is a diagram showing how the MTA-100 headers refere to the components:
 for troubleshooting it might be helpful to have the silkscreen:
   __________
 Controller LFO BUILDING NOTES:
 the chart below shows how to wire the potentiometers and the jacks, if you don't use the front panel components PCB:
 ATTENTION: the PCB omits diode D2. i found the trigger to be fine without it.
 however, if you experience occasional double triggers, solder it in parallel to R44.
 ATTENTION: the P-JFET 2N5461 comes in different pinouts!
 so check the datasheet of the specific brand you use!
 (thanks to rosch for this find)
 and here is the silkscreen of the circuit PCB:
| Back to top |  |
| StormB
|  Posted: Mon Jan 13, 2014 1:51 am    Post subject: |    |
| Hi bin mit 2xLFO Platinen dabei
| Back to top |  |
| bod
|  Posted: Mon Jan 13, 2014 7:50 am    Post subject: |    |
| 2x lfo printed front panels 2x vco printed front panels
 I should have ordered these the first time along with the pcb's!!
 Bod
| Back to top |  |
| scriptstyle
|  Posted: Tue Jan 14, 2014 9:10 am    Post subject: |    |
| ^agreed
 I am down for
 2X VCO
 1X LFO
| Back to top |  |
| adnauseam
|  Posted: Thu Jan 16, 2014 1:39 pm    Post subject:
Me too |    |
| My first eurorack purchase!
 I'd take 2 of each PCB
 (4x pcb = 40 USD)
 and 2 of each PRINTED front panel
 (4x panel = 52 USD)
 Plus I'm in Canada so 6 USD shipping (perhaps more? I'll take this as open to change)
 98 USD if I calculated correctly.
| Back to top |  |
| adnauseam
|  Posted: Thu Jan 16, 2014 3:11 pm    Post subject:
Newb question.. |    |
| So after looking at the original schematics at http://electro-music.com/forum/topic-54623.html I saw that it's talking about +/-15V where as I understand Eurorack specs to be +/-12v.
 Haven't yet found alternate circuit diagram and being a novice I don't yet understand what to do to adapt it for 12v
 Easy to accomodate?
| Back to top |  |
| AlasdairMoons
| Back to top |  |
| alangave
|  Posted: Sun Jan 19, 2014 1:13 pm    Post subject: |    |
| Hi,
 I'm for 1 circuit VCO PCBs + 1 frontpanel PCB + 1 euro frontpanel
 Will be my 3rd TH module, Fonik's design!
| Back to top |  |
| adnauseam
|  Posted: Mon Jan 20, 2014 6:56 pm    Post subject:
Ooh I get it. |    |
| I misunderstood there as being a PCB and the option of a front panel - printed or unprinted.
 I'll take:
 1 VCO - complete set
 1 LFO  - complete set.
 Ignore my previous post
| Back to top |  |
| Rivelen
 G2 patch files: 12
|  Posted: Tue Jan 21, 2014 12:37 am    Post subject: |    |
| Hi, 1 x LFO PCB for me please !
 Thanks.
| Back to top |  |
| uriahheep
|  Posted: Tue Jan 21, 2014 4:45 am    Post subject:
555 vco Subject description: pcb
| Hello Can you put me down for
 6 x 555 VCO circuit PCBS
 Thank you
| Back to top |  |
| isacsen
|  Posted: Wed Jan 22, 2014 4:12 am    Post subject: |    |
| I'm interested in:
 2 x circuit 555-VCO PCBs
 2 x circuit Controller LFO PCBs
 Trying to restart my modular building. This will be a nice project.
 Thank you.
| Back to top |  |
| piedwagtail
|  Posted: Thu Jan 23, 2014 9:31 am    Post subject: |    |
| 4 x circuit Controller LFO PCBs
 please.
 Robert
| Back to top |  |
| drapdap
|  Posted: Thu Jan 23, 2014 12:30 pm    Post subject: |    |
| hello Fonik!
 i'll take 8 pcb's of the 555-VCO's if that is possible, taht is 4 for me, 4 for
 a friend, i build, he pays. Yes Matthias, he's more reliable than me.
 should i pm you?
 robert
| Back to top |  |
| flyweight303
|  Posted: Fri Jan 24, 2014 3:26 am    Post subject: |    |
| Hi Mathias
 Good to see youre doing another run.
 For me please:
 1 vco PCB
 1 controll pcb
 1 panel
 4x pcb LFO
 (removed 4 vco pcb's)
| Back to top |  |
| shiftr
|  Posted: Fri Jan 24, 2014 12:06 pm    Post subject: |    |
| 2x circuit VCO PCB's please
 shipping to the Netherlands...
| Back to top |  |
| Acilator
|  Posted: Fri Jan 24, 2014 1:32 pm    Post subject:
555VCO |    |
| For me,
 2 X VCO complete (pcb's + panel)
 2 X LFO Complete (pcb's + panel)
 Also Shipping to the Netherlands
| Back to top |  |
| ioannis taf
|  Posted: Sat Jan 25, 2014 3:45 pm    Post subject: |    |
| Hello Matthias, I would like,please:
 2 x circuit VCO pcbs,
 1 x frontpanel VCO pcb,
 2 x circuit LFO pcbs,
 1 x frontpanel LFO pcb.
 (and if available, older pcbs)
 Shipping to Greece.
 Thank you,
 Ioannis
| Back to top |  |
| mono-poly
|  Posted: Sat Jan 25, 2014 6:12 pm    Post subject: |    |
| I'd like 3 vco pcbs and panels And i'd like 2 lfo pcbs and panels
| Back to top |  |
| jukingeo
|  Posted: Sat Jan 25, 2014 9:58 pm    Post subject: |    |
| 3 x VCO Circuit PCB
 Shipping to 11702, USA.
 Thanx,
 Geo
 Lover...I won't take a back seat, tonight.  Got some dancin' to do.
| Back to top |  |
| avouts
|  Posted: Sun Jan 26, 2014 2:15 pm    Post subject: |    |
| 4 cirquit vco pcb's and 2 adsr pcb's ( if available )
| Back to top |  |
| alfonso
|  Posted: Mon Jan 27, 2014 3:30 am    Post subject: |    |
| arghh! am i late?
 i'd take 4  OSC PCBs and 4 OSC PANELS
| Back to top |  |
| piedwagtail
|  Posted: Mon Jan 27, 2014 11:15 pm    Post subject: |    |
| Alfonso, if you are from Ferrara anything is possible   He's put the deadline back due to Chinese New Year - factory is closed- the post was updated at Muffs for 7thFeb latest orders.
 Robert
| Back to top |  |
| alfonso
|  Posted: Tue Jan 28, 2014 3:07 am    Post subject: |    |
|  	  | piedwagtail wrote: |  	  | Alfonso, if you are from Ferrara anything is possible   |
  yes i am  the beautiful magic city   thanks for the info !
 so i'm in for 4 vco pcb and 4 vco panels!
 a.
| Back to top |  |
| fonik
|  Posted: Tue Jan 28, 2014 4:56 am    Post subject: |    |
|  	  | scriptstyle wrote: |  	  | ^agreed
 I am down for
 2X VCO
 1X LFO
 just the circuit PCBs i guess?
| Back to top |  |
