power cables vs audio cables
Page 1 of 1 [6 Posts]
the architech
PostPosted: Sat Jan 11, 2014 10:14 am    Post subject: power cables vs audio cables Reply with quote  Mark this post and the followings unread
So it was suggested to me that I use XLR to run dual ac power to my synth (I don't want to hardwire, I'd like the PSU to stay independent), but that most XLR is made for low power audio. Is this true, is there more impedance if I were to use the 3' XLRs I have laying around? If I do make XLR cables, how would I make them for power as opposed to audio? Is it a wire gauge thing?
Would it be easier if I just used a standard 3-prong power jack?
Audio files: 566
PostPosted: Sat Jan 11, 2014 2:21 pm    Post subject: Re: power cables vs audio cables Reply with quote  Mark this post and the followings unread
hi, it's me again Wink
what you'll be connecting is the dual DC voltage (not AC). anyway, yes it's a gauge thing. With a thicker wire you can get more current with less
loss because the resistance is lower, which means less noise. but you could try it. I just use standard mains wires for it (something you would
use to connect a lamp or something). I'm not sure if the impedance would matter for use as a power cable but it might. That's actually
something I'm curious about myself.
assuming you mean the ones that you normally use to connect a device to the mains power.
Never use those for anything else out of safety reasons. no no
the architech
PostPosted: Sun Jan 12, 2014 8:09 am    Post subject: Re: power cables vs audio cables Reply with quote  Mark this post and the followings unread
Never use those for anything else out of safety reasons. no no[/quote]
What's unsafe about them? You had said before that I just needed a 3-prong cable, and they are intended for power.
Audio files: 216
PostPosted: Sun Jan 12, 2014 8:30 am    Post subject: Re: power cables vs audio cables Reply with quote  Mark this post and the followings unread
Well .. one day you might confuse them with a mains lead or outlet and <kaboom> Shocked
the architech
PostPosted: Sun Jan 12, 2014 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, but if regular XLRs have impedance issues, I could just as easily use an audio cable by accident. Doesn't result in a frying, but still undesirable. I'd really rather not make my own cable, but I will if I have to. And if I have to, seems like I should use non-typical connections to avoid confusion with any other standard cable, eh?
Audio files: 566
PostPosted: Sun Jan 12, 2014 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, using a kind of connector that you don't use for anything else would be ideal. I don't use XLR for anything else myself (might change in the future)
so I can't confuse it (and the cables I used are much less flexible then microphone cables). But I like the ones Gary posted in the other thread.
